by harlansmart » Wed May 29, 2013 6:04 pm
10/10
Those rims look like sick sexy dope & mean as all hell genuine JDM rolling stock, what are they & what did they weight in at vs. the others
Shane. wrote:That looks way cleaner!
Holy crap,
to me that spolier you link to looks like some sort of over grown boomerang, YuK.
by chris » Thu May 30, 2013 8:36 am
harlansmart wrote:10/10
Holy crap,
LOL boomerang, at least the car will always come back to you (Probably because you couldn't get rid of it with that spoiler)
by Skilfil » Thu May 30, 2013 11:32 am
Thanks feels good to finally have a car I can show off. I'll pass on that wing, its a bit huge. I think I'll be going for a TougeRun style spoiler anyway.
Just a quick question, the trackday I'm going to, do you guys reckon this bar will be fine? Its a bolt-in bar too.. (sorry I know I'm whoring pictures all over the place, only way I can show you guys, last one, I promise)
by chris » Thu May 30, 2013 11:39 am
Nice pictures.
I will be honest, get a new bar. I'm sure they will let you on.. but that bar will not do jack.
Get a 4 point bar. I think Kieran (Furai) has had one made up. Talk to him =]
Shane.
by Shane. » Thu May 30, 2013 12:26 pm
I like pictures, especially with backdrops like that. Whore away!
by Furai » Thu May 30, 2013 2:00 pm
You will have to have a talk to the track organisers. Some of those are actually pretty strong but personally I wouldnt trust it.
This is the one I got made up. Not super cheap though. 44mm MSNZ spec Rollbar. You can get a bolt in Cusco for about $700, this would be a similar price but shop around and get a solid quote. Mine was slightly cheaper because I did all the stripping of the interior and that.
Also this is welded in. Bolt in is for virgins as Bwarp would say.
by BRM » Thu May 30, 2013 6:43 pm
How verticle is the main hoop?
Why haven't you gone for any diagonals or horizontal?
by siren676 » Thu May 30, 2013 7:31 pm
because hes a tall lanky bastard and needs the seat back as far as possible
by CordedBowl » Thu May 30, 2013 7:34 pm
Furai's got a rollbar, rad! (I'll race ya~)
Your car is looking great Skilful
by BRM » Thu May 30, 2013 7:38 pm
siren676 wrote:because hes a tall lanky bastard and needs the seat back as far as possible
But, the hoop goes to the floor,
like a proper one should, and instantly that must restrict seat positioning.
But, his seat Is mounted to the floor, so that helps anyway..
I'm just about getting mine done too,
But it's getting diagonals and harness bar...
by Furai » Thu May 30, 2013 8:08 pm
Diagonals can be added later if wanted, I wasnt keen on the restriction to rear view to be honest.
Main loop is not vertical, has a slight outwards stance at the bottom.
Also Corded Bowl, Ill race ya
by siren676 » Fri May 31, 2013 5:38 pm
Tried repairing the tee piece on the thermostat housing but couldnt fit the drill in to make the larger hole for the tap so have had to disassemble half the motor to get the housing out.
After removing the housing and drilling the new hole we found out that ive been provided with a intermediate tap when i needed a starter one.
Dads hopefully going to try find the correct one for me tomorrow
by GRUVBB » Fri May 31, 2013 6:23 pm
It's called a primary tap. I probably got one in my kit if you luck out. Is it M10 x125? Primary first then intermediate and then plug tap. FYI.Kerosene is a good cutting fluid for alloy
by siren676 » Fri May 31, 2013 6:46 pm
Yeah i needed the primary tap, the size is 1/4" BSP
by GRUVBB » Fri May 31, 2013 7:07 pm
I got BSW.Will check if i have BSP in that size. Will PMYou on that one.
by Skilfil » Fri May 31, 2013 7:22 pm
Furai wrote:You will have to have a talk to the track organisers. Some of those are actually pretty strong but personally I wouldnt trust it.
Nice for some reason I never thought you had a rollbar, yeah definitely weld in bar. I've been given pricing of $700-$800 for a bar similar to yours, with some diagonal bars, weld-in and clears a hardtop too.
Tax refund is on its way, so should have myself a new bar then. I'd rather spend some money and stay alive than give myself a new haircut via tarmac.
by SLYDIT » Fri May 31, 2013 7:27 pm
Pretty sure they are 1/8 bsp not 1/4
by siren676 » Fri May 31, 2013 8:04 pm
SLYDIT wrote:Pretty sure they are 1/8 bsp not 1/4
oh crap too late now holes already been drilled, someone told me to go 1/4" BSP.
Ah well, biggers normally better
theres definitely enough meat left in the housing to take a 1/4 fitting
by GRUVBB » Fri May 31, 2013 8:28 pm
You can get a threaded reducer from engineering supplier if need be. Easier when ithey both BSP. Could try Waitemata Hydraulics. Auckland Engineering Supplies. Paykels etc. dependsvwhere you are located. Use the phone first....
by SLYDIT » Fri May 31, 2013 9:30 pm
bsp fittings are sized by the inner diameter of the hose. so the threads are always MUCH bigger than what youd think. a 1/8" bsp thread is about 10mm actual size. for reference i used a 1/8" bsp fitting for the dual feed fuel rail mod
by SLYDIT » Sat Jun 01, 2013 1:09 pm
today i finally got around to fixing my drivers door lock. I can actually open the door now!
by BRM » Sat Jun 01, 2013 3:55 pm
Side on and boot shot pls
by WideOpenThrottle » Sat Jun 01, 2013 4:51 pm
Looks like mine without the Diagonal & harness bar.
- When it was blue
by BRM » Sat Jun 01, 2013 5:54 pm
Ah cool
How much does it restrict seat travel..
Unless yours is on the floor...
