Ride height.
malcster
Ride height.
Post by malcster » Sun Dec 02, 2012 9:10 pm
when i lowered the car today as have put 15s on it i found to get same ride height left to right i had to wind the adjuster all the way down on the rh rear side and put some tension on the lh spring and visa vera on the front.
even with it fully wound down the rh rear is still slightly higher(about 2-3mm) than lh side. and same with front .
is this normal?
1998 NB MX5 RS TURBO.
aidwano
Post by aidwano » Sun Dec 02, 2012 10:46 pm
I wouldn't say that's normal but mine is a little uneven.
But what do you mean by tension in the spring? And are you measuring to the guard or ground clearance?
malcster
Post by malcster » Sun Dec 02, 2012 10:57 pm
with car up on the jack the lh rear i screw up the rings until they put tension on spring where as the rh side the rings are screwed all the way downwards so spring isnt captive.
yeah measuring from ground to top of guard.
Post by Mr. Shine » Mon Dec 03, 2012 8:16 am
So you're having to preload the spring to match height all around, whereas if you set the springs to be just captive against the locking collar all around the height is uneven?
Post by WideOpenThrottle » Mon Dec 03, 2012 8:58 am
The joys of adjustables :D i had the same thing with my sons car..kept going round in circles so gave up in the end & left it as close as we could get it.
I could be wrong but i think adjustables are primarily designed for corner weight of each wheel rather than height even-ness.
The chassis stiffness means as you adjust one it affects the others too!
malcster
Post by malcster » Mon Dec 03, 2012 9:12 am
Mr. Shine wrote:So you're having to preload the spring to match height all around, whereas if you set the springs to be just captive against the locking collar all around the height is uneven?
not really...its just weird that the rear rh side needs the locking rings screwed ring down away from the spring whereas the lh side needs the locking rings to be up and pressing on the spring and the front is the opposite.
Post by warrior » Mon Dec 03, 2012 10:16 am
mine was like that also.
Post by Furai » Mon Dec 03, 2012 3:40 pm
What kind of coilovers have you guys got? Most have pre-load and height adjustment as separate things.
Also are your damper settings all the same?
malcster
Post by malcster » Mon Dec 03, 2012 4:07 pm
i have teins with the adjustable dampning which sits inside car.
Post by Kieran » Wed Dec 05, 2012 10:34 am
drivers side sits higher usually to account for the weight of the driver sit in the drivers seat and get someone to measure
Post by Mr. Shine » Wed Dec 05, 2012 12:13 pm
I don't think that's something usual in coilover design, however, rather needs to be taken into account when installing and setting the ride height as desired.
