New Plugs and Leads
New Plugs and Leads
Post by evel » Wed Aug 08, 2012 8:34 pm
Hey Ya'll. What do you recommend in terms of spark plugs and ignition leads. Im talking the best of the best!
dynofiend
Post by dynofiend » Wed Aug 08, 2012 8:55 pm
Gonna put my grumpy old man hat on here, and say that fancy-pants plugs and leads make bugger all difference unless the old ones are poked or have the wrong gap. Platinum, split electrodes and all that rubbish make no difference in mx5s. Save money and replace more often and check your gaps ;)
A spark will ignite the mixture whether it comes from a rare metal electrode or not 8)
Post by evel » Wed Aug 08, 2012 8:59 pm
and im gonna put my iv never done this before hat on and say, what gaps and heat range(?) do mx5's like?
Post by warrior » Wed Aug 08, 2012 9:19 pm
I disagree just a little here, agree with the leads just buy some new ones. As for the plugs I bought the best ones I could, just from supercheap I think they were plantim. They did make a diffrence. The car reved out quicker and much smoother. Dont change the heat range just buy good plugs, (talk to supercheap) they will last forever and are woth it.
Post by SLYDIT » Wed Aug 08, 2012 9:32 pm
the big difference is whether they will last more than a year or not. History has proven that the NGK leads stand the test of time better than others. Same with plugs. i wont use anything other than good old fashioned NGK's.
Post by brownie » Wed Aug 08, 2012 11:33 pm
No matter what... go NGK BKR6E 11 standard or platinum,the iridium's are just overkill .
Same for plug leads,NGK,In saying the the ULTIMA 8mm silicone leads are nice as well,Run those on my own car
Re: New Plugs and Leads
Post by Stevo » Thu Aug 09, 2012 6:29 am
evel wrote:Hey Ya'll. What do you recommend in terms of spark plugs and ignition leads. Im talking the best of the best!
If you are looking for "The Best of the Best", I had "Nology Hotwires" on mine http://www.nology.com/products_old.html heres a photo http://www.mx5forum.co.nz/garage.php?mo ... age_id=483
They are handmade and have capacitors built into each lead. :D
Post by evel » Thu Aug 09, 2012 8:57 pm
so heat rating of 6 with 1.1mm gap?
broomfish
Post by broomfish » Fri Aug 10, 2012 6:35 pm
I have NGK BKR6E-11, BKR6EIX-11 plugs and RC-ZE21 leads in stock
http://www.broomfish.co.nz/products_ymm ... A6C&Year=0
regards
Peter Lee
Broomfish
www.broomfish.co.nz
