NA6C Cam timing mod
DeeCee
NA6C Cam timing mod
Post by DeeCee » Sat May 26, 2012 7:23 pm
I am considering doing the cam timing mod to my NA6C but have not been able to find a link to any instructions about how to do this.
Can anyone help me ?
Post by sprsta » Sat May 26, 2012 7:58 pm
you need a timing light
go here and folow the instructions but set the timing to 14 degrees instead of 10
http://www.flyinmiata.com/techline/olde ... asp#TIMING TIPS FOR THE 1.6
DeeCee
Post by DeeCee » Sat May 26, 2012 8:18 pm
Thanks sprsta, I am onto that one.
The mod I am referring to changes the inlet and exhaust cam timing by swapping the timing gears (from memory)
Post by SLYDIT » Sat May 26, 2012 9:43 pm
its called the "exhintake" mod or something similar.
i remember it was only for one engine type...can't remember if it was the 1600 or 1800
DeeCee
Post by DeeCee » Sat May 26, 2012 10:23 pm
Yes you are correct SLYDIT, I finally found some more info and seems it applies to the 1.8 engine, not the 1.6.
Post by Angreal » Sun May 27, 2012 10:45 am
Speaking of exhintakes... Could anyone point me in the right direction for obtaining a reasonably priced exhaust camshaft?
Post by REDBEN » Sun Jun 03, 2012 1:14 pm
Angreal wrote:Speaking of exhintakes... Could anyone point me in the right direction for obtaining a reasonably priced exhaust camshaft?
Give Henry a call at Auckland Cams 0274860400, He's the lead Techie at ACL and will have a range of options available.
Post by Angreal » Fri Jul 13, 2012 5:38 am
Can anyone also recommend a place to do the timing bump on my car?
Post by sprsta » Fri Jul 13, 2012 8:03 am
ill do it if you like
Post by Angreal » Fri Jul 13, 2012 8:50 am
sprsta wrote:ill do it if you like
Sweet. I'll pop by in a couple weeks dependant on whenever my container arrives with the bushings and exhaust :D
halberd
Post by halberd » Fri Jul 13, 2012 10:07 am
I'm also interested, if you are interested in doing it for me. How much would it cost?
'91 Eunos Roadster
