Hardtop seals and wiring
JiB
Post by JiB » Wed Feb 10, 2010 9:51 am
Have recently acquired a hard top with a heated window (cheers brownie!).
Unfortunately, the seal around the rear window is damaged. I have some black Urethane I thought I could use - is there any downside to this?
Otherwise, are normal glazers (Smith & Smith, et al) able to replace the seals without costing a fortune?
edit: Do I have to install a switch to activate the demist function too? Or is there some switch I haven't discovered?
Post by Timmo » Wed Feb 10, 2010 1:13 pm
If black goo works, then it works ;)
You will need to aquire and wire in the switch....im not even sure if a heated rear window was an option on the NA series?
Dez
Post by Dez » Wed Feb 10, 2010 9:03 pm
"im not even sure if a heated rear window was an option on the NA series?"
Yup. Sure was, from 1992/93 models on. The plug sits on the parcel
shelf behind
the passenger seat.
Quoting Timmo <mx5talk@mx5forum.co.nz>:
....im not even sure if > a heated rear window was an option on the
NA series?
JiB
Post by JiB » Wed Feb 10, 2010 10:48 pm
Righto, there is wiring - needs a relay, fuse and a switch I think. I think I may have to find a combination switch because it shares the foglight slot..
Post by sprsta » Thu Feb 11, 2010 7:21 am
a glazer will be able to replace the moulding pretty easy
mazline
Post by mazline » Thu Feb 11, 2010 5:29 pm
I can sort the fuse set up for you ,Does your car have Manuel aerial or electric?
JiB
Post by JiB » Thu Feb 11, 2010 7:25 pm
mazline wrote:I can sort the fuse set up for you ,Does your car have Manuel aerial or electric?
An electric one, so the box is already there I think, just needs a fuse in it :)
mazline
Post by mazline » Fri Feb 12, 2010 4:01 pm
I have found a MX5 demister switch in the draw !!,It should go in the middle hole on the R/H lower part of the dash,You should have the loom already there.
10amp fuse is what you need in the fuse holder in the boot(Next to the aerial fuse),Not sure if a relay is required or not ,I will do more homework on that,unless someone else can shed some light.
The switch is yours if you want it.
JiB
Post by JiB » Fri Feb 12, 2010 4:50 pm
mazline wrote:I have found a MX5 demister switch in the draw !!,It should go in the middle hole on the R/H lower part of the dash,You should have the loom already there.
Bugger, that hole is currently occupied by the factory foglight switch :(
I'll investigate further when I have time!
Post by Angreal » Tue Mar 30, 2010 10:16 pm
Yeah I just bought a hardtop also with the demister. So to get it working, I just need to get a demister switch put it?
Also, the plug on the hardtop is different to the plug in the back of the car. I've managed a temporary work around but does anyone know where I can get a NA plug/wire to use for the hartop?
Post by sprsta » Wed Mar 31, 2010 7:29 am
if you get a switch ill get it working for you when you pick up your top
Users browsing this forum: Google [Bot] and 25 guests
