Better engine technology and the story of a happy clutch.
Post by Habanero666 » Sun Nov 01, 2009 8:18 pm
Hard times....
I got sick of low boost, a slipping clutch type situation, turbo lag, fasteners coming loose, 'lunched' my forth NA gearbox and have got the "just not satisfied with my engines power output" feeling, so have got some parts and done some machining;
New clutch set up,
Heavy duty G box from an NB ( big thanks here to Mark Brown at Mazline in ChCh!),
Rebuilt turbo with famous herbs and spicyness, port matched and over sized exhaust manifold,turbo stud set with nordlok fasteners and ported/ over sized TD04 turbine housing.
Have to put the clutch and box in, but the power increase from the above work spelt out the current clutch and gear boxes doom
Custom crankshaft work and flash bottom end stuff coming soon.
dynofiend
Post by dynofiend » Sun Nov 01, 2009 8:59 pm
Tasty! I had a paddle clutch in one of my old cars, you soon get used to them and they make for a fast change!
Love the seat cushion packaging :)
Whats the difference in the NB gearboxes that makes them stronger? What was it that kept blowing in the NA box?
Also, whats the car in the picture of the gearbox with the neat white letter tyres?
Post by Habanero666 » Sun Nov 01, 2009 9:31 pm
dynofiend wrote:Tasty! I had a paddle clutch in one of my old cars, you soon get used to them and they make for a fast change!
I am looking forward to trying out this clutch as it is the only choice before a twin plate set up and another $1000nz or so. I have got a 4kg flywheel for this as well, skillful lathe use there.
Mark at Mazline did a fantastic job packing this one up! Also he is sending me a brand new shifter boot, as this one was a bit worse for wear. Top service!
The difference in the boxes are the case thickness and the bigger sized input shaft bearing you can machine them up to carry.
What fails? input shaft bearing craps out due to additional unpredicted torque loading.... then that provides excessive endfloat of the input shaft....then the gear teeth get a little to much backlash....etc etc
The car is a Mopar '67 Valiant. Looks nice?
Post by brownie » Sun Nov 01, 2009 9:54 pm
I'm pleased the box got to you OK,The boot is organized as soon as the Mazda /Ford boys decide to go back to work at the Distribution Warehouse.(Been on strike for the last 2 weeks)
Cool old mopar!!.Nice to see a good mix of cars in the garage.
Mark (mazline/Brownie)
Post by Habanero666 » Sun Nov 01, 2009 10:30 pm
Yep thanks for that! I hope the team at the distribution center get what they are after.
The Mopar is a friends treasure, that I have the pleasure of tidying up and ironing out a few creases cosmetically , such a work of art in so many ways! It's one of four that was used to test bed the V8. It came to NZ in 1971.
Post by brownie » Mon Nov 02, 2009 9:45 pm
I hope the Mazda centre does two,BUT,I have been waiting 2 weeks now to send some new parts to Mauritius for a customers Mazda3 and starting to get a little peeved.
No Mazda /Ford dealer around the country are getting any parts for customers cars,Our local Mazda dealer hasn't sold a new part not in stock for 2 weeks now !!
Post by Habanero666 » Tue Nov 03, 2009 5:50 am
brownie wrote:I hope the Mazda centre does two,BUT,I have been waiting 2 weeks now to send some new parts to Mauritius for a customers Mazda3 and starting to get a little peeved.
Oh dear! I have been waiting for about three weeks for some sneaky mazdaspeed parts orders via the local branch, I was told yesterday that the overseas order person had been on "holiday" and was back at work today...... ah, the subtle art of lie :lol:
I am currently developing a high pressure oil pump to be used in conjunction with full groove race spec mains bearings. Bit O' this bit O' that, to acheive a stable mid range and top end oil flow/pressure for high boost application.
Post by Habanero666 » Tue Nov 24, 2009 4:29 pm
Here is a picture of what goes wrong with the transmission when subjected to "beating up on", this was done on the strip by a American geezer.
Gotten Himmel!
Post by Habanero666 » Thu Dec 31, 2009 1:05 pm
At last the new clutch and gearbox are in :D.
Had a fun time last night when for no apparent reason the ignition system dropped off on coil 1&4 after a heated road test. lucky it shat itself in the garage before I turned it off!! The ignitor was steaming 8) and both number 1 and 4 spark plugs had fouled with fuel.
I will award someone a beer of your choice (just one), couried to your address if you can guess what caused it, if you nail it I will send two!
I have mitsubishi lancer gsr ignition coils and ignitor ( to handle higher boost, but works the same so isn't the problem), new spark plugs and leads, all ran by a Flyin Miata link mark 1, yum yum!
The solution was an hour of wiring and component diagnostics, oh yeah and the replacement part cost 55c...... back together and away it went, drives better right across the whole rev range, mmm mmm smooth.
Hahaha this should be fun :wink:
Go on have a guess!
Happy New Year!
Zoom Zoom
mx5mike
Post by mx5mike » Thu Dec 31, 2009 1:13 pm
I'll have a crack at that...
Your spirited drive heated up the windscreen washer bottle and the increased
pressue blew the outlet hose off which pis*ed water over the coil pack.
Mike.
1990 FMII
From: Habanero666 [mailto:horsepower@mx5forum.co.nz]
Sent: Thursday, 31 December 2009 1:05 p.m.
To: horsepower@mx5forum.co.nz
Subject: [MX5Power] Re: Better engine technology and the story of a happy
clutch.
Hahaha this should be fun [Wink]
Go on have a guess!
Happy New Year!
Zoom Zoom
http://www.mx5forum.co.nz/viewtopic.php?p=43766#43766
Post by Habanero666 » Thu Dec 31, 2009 1:27 pm
hahaha, No washer bottle under my bonnet. Thanks for the shot at it, made me laugh:D
Coil packs are over $100 to replace so the hint is the price!
Post by SLYDIT » Tue Jan 12, 2010 10:35 pm
the earth strap to the block came off?
Post by Habanero666 » Wed Jan 13, 2010 12:33 pm
Not that simple, all though I wished it were at the time :D
Nice guess though.
91 V-Spec
Post by 91 V-Spec » Tue Mar 02, 2010 10:58 am
No one ever guessed this one?
'91 Eunos Roadster V-Spec
http://www.cardomain.com/ride/3837239
Post by Habanero666 » Tue Mar 02, 2010 1:16 pm
Nope. Do you want to know the answer?
91 V-Spec
Post by 91 V-Spec » Tue Mar 02, 2010 1:21 pm
Nah, that would be like telling me who the Stig is, its more fun not knowing! :P
Post by Habanero666 » Tue Mar 02, 2010 2:04 pm
I will only tell as a parting gift. I have listed my car on trade me and won't be on this forum much longer.
I have the same avatar as this forum on TM :wink:
