Brake fluid leak
DBM58
Brake fluid leak
Post by DBM58 » Tue Jul 12, 2005 4:23 pm
I have a from the area of where the brake hose meets the rear wheel. Can anybody suggest a reliable / reputable repairer in the Mount Wellington / Panmure area.
Thank you for your help
David Moughtin
David
Bob Anderson
Brake fluid leak
Post by Bob Anderson » Tue Jul 12, 2005 4:26 pm
Try Sterling Clutch & Brake Ltd on cnr Neilson St & Onehunga Mall. I've
found them excellent.
Dr Bob
EricW
Brake fluid leak
Post by EricW » Tue Jul 12, 2005 4:59 pm
I concur, they did a damned good job on the BMW recently
Eric
From supasparky@yahoo.co.uk Fri Apr 27 16:57:22 2007
b=r6rYn0llrITQjQFFKUiXhlLt8hJaCNoHeux8NKyyYW+Ck8yz6tiiHr3wljhvDfyzM0iWmQBpexVyWNK5Q6EaMbeyTGTVTyGJzxObEM8b8njQqvBraoXRgUbTj+0Tm8GhiaNLQrRsMUl1PpUqsHS7HKvIO1TdNpnpF8WQTmrQx60=
Date: Tue, 12 Jul 2005 06:03:36 +0100 (BST)
Subject: HOW NOT TO PARK AN MX5
In-Reply-To: <004601c5869b$78b9e9f0$0301010a@oemuvenry0wbi0>
MIME-Version: 1.0
Precedence: list
Message-ID: <qUp25D.A.3DB.VdYMGB@L733>
Check out this link:
http://www.mx5ocforum.co.uk/viewtopic.php?t=20968
Pictures say it all really.
Glenn "SLYDIT"
DBM58
Brake fluid leak
Post by DBM58 » Thu Jul 21, 2005 12:43 pm
The brake leak was repaired yesterday,luckily I'd picked the day that they had put aside for red cars.
The cause of the problem was pitting on the bore of the brake cylinder caused by water build-up in the brake fluid. An expensive reminder that brake fluid does absorb moisture and should be replaced regularly. Every twelve months was a suggested interval. The fluid had leaked onto the brake pads so they needed replacing too.
As regards Sterling Brake and Clutch, Bob and Eric's comments were borne out in that they seemed to be a helpful group that provided competent service.
David Moughtin
David
Perry perry
Brake fluid leak
Post by Perry perry » Thu Jul 21, 2005 6:41 pm
How much did they charge? When one of my rear brakes started leaking the
seals were replaced and I think I was charged around $265
From jifjif@gmail.com Fri Apr 27 17:37:18 2007
h=received:message-id:date:from:reply-to:to:subject:in-reply-to:mime-version:content-type:content-transfer-encoding:content-disposition:references;
b=RTdeiU55pLnTj/4LyFQrHnLI6VoL6siqECMkJKys3f3Ku86BA8YntW+d3tW929HJoHfrpRuCMryUFtfA/O6x/OiIIV5wW6wv8JXcb5yQeJwoZLovrZgM52R0XrJCgZ5c6tgCSEAFi77NFFp7OtXLnCuQ7B6bjXnKCkK/fENmfWY=
Date: Fri, 22 Jul 2005 08:33:24 +1200
To: mx5list@mx5club.org.nz
Subject: Fwd: AutoWeek cover story on 2006 MX-5
In-Reply-To: <sympa.1121906514.22207.479@dauntless.milewski.org>
Mime-Version: 1.0
References: <sympa.1121906514.22207.479@dauntless.milewski.org>
Precedence: list
Message-ID: <Th4oeD.A.AxD.CxYMGB@L733>
buy now ! :)
---------- Forwarded message ----------
DBM58
Brake fluid leak
Post by DBM58 » Fri Jul 22, 2005 1:48 pm
Brake pads (pair) - $52.00
Discs (each) - $65.00
Caliper (re-conditioned) - $195.00
Piston - $60.00
Fluid - $15.00
Labour - $124.00
So now I have no money left for lunch for the next few months.
David Moughtin
David
Return to “2005”
