Lost a screw....
Lost a screw....
Post by Furai » Sat Feb 18, 2012 7:09 pm
So i lost a screw off the Airfoil wiper thing on the windscreen wiper arm and Its gone under the bonnet down behind the front quater on the drivers side. I cant find it and its a 3.5mm screw about 8mm long.
I cant seem to find them anywhere does anyone know a place? A whole new arm is $67GBP and I just want the airfoil thing all bolted down. Even some hex head button top screws would be great!
Post by Euen » Sat Feb 18, 2012 8:15 pm
Where are you? We can suggest places but there is not much point if you are not in the area.
Post by Furai » Sat Feb 18, 2012 9:03 pm
Im on the Shore in Auckland
2low2c
Post by 2low2c » Sat Feb 18, 2012 9:37 pm
it will not be 3.5 mm it will be ether 3mm or 4mm ,or it could be imperial
on the shore your best bet would be The bolt shop on archers rd .
Post by brownie » Sat Feb 18, 2012 9:51 pm
I believe a good Mazda parts specialist has a add running here in classifieds,They might be able to help.
(Will be of more help than the CR forum in the states) :wink:
Post by Euen » Sat Feb 18, 2012 9:59 pm
+1 to the Bolt Shop. Won't be open again till Monday now though.
My ones are M3.5 x0.6 x 5mm long with a captive spring washer.
Good luck
Post by Furai » Sun Feb 19, 2012 8:07 am
Thanks guys ill try them.
ross
Post by ross » Sun Feb 19, 2012 1:01 pm
I have one you can have.
Ross.
www.mx5mart.
