Check vavle
Check vavle
Post by WideOpenThrottle » Sat Jul 24, 2010 7:21 pm
Do i need one?
Insert a check valve in the vacuum line going
to the solenoid that feeds the charcoal canister.
Be sure that you put it in the correct line (the
one between the manifold and the solenoid, not
the line between the solenoid and the canister)
and in the correct orientation (with the blue side
towards the solenoid
[Excerpt from Flyin Miata install webb site]
Post by sprsta » Mon Jul 26, 2010 7:25 am
you could do that or remove the solinoid and canister all together
Post by WideOpenThrottle » Mon Jul 26, 2010 8:04 am
So whats the reason for the solenoid/canister in the fisrt place?
I like the idea of removing parts that i dont need!
Post by sprsta » Mon Jul 26, 2010 8:52 pm
its to catch the hydrocarbons coming out of the tank then the solinoid shoots it off to the engine to be burnt later on
here is some help with what to do to remove it all
http://www.mx5nutz.com/forum/index.php? ... l=charcoal
this way it just vents it into the sub frame
Post by WideOpenThrottle » Mon Jul 26, 2010 9:09 pm
Cheers sprsta-mite take it out 2moro after i drop my blower off 2 have a birthday! :D
Post by SLYDIT » Fri Jul 30, 2010 9:07 pm
just throw a cheap check valve in it. i did that to mine when i turbo'd. a quick trip to pick a part for some bits and pieces and i was set.
Post by WideOpenThrottle » Sat Jul 31, 2010 8:50 am
Its out slydit :D
Users browsing this forum: Google Adsense [Bot] and 48 guests
