Check vavle
Check vavle
Do i need one?
Insert a check valve in the vacuum line going
to the solenoid that feeds the charcoal canister.
Be sure that you put it in the correct line (the
one between the manifold and the solenoid, not
the line between the solenoid and the canister)
and in the correct orientation (with the blue side
towards the solenoid
[Excerpt from Flyin Miata install webb site]
its to catch the hydrocarbons coming out of the tank then the solinoid shoots it off to the engine to be burnt later on
here is some help with what to do to remove it all
http://www.mx5nutz.com/forum/index.php? ... l=charcoal
this way it just vents it into the sub frame
Users browsing this forum: Google Adsense [Bot] and 49 guests
