annoying rattle 93 mx5
thanks guys
this is a great site.
I may have the answer. My NA used to drive me mad with the same thing, I
can't remember where I got the answer... wait found it.... on the original
MX5 email list/forum Nov 04. I was also convinced it was way under the dash,
way over on the passenger side.
Anyway it turned out that this was a very common issue with the... wait for
it.... bonnet catch.... The fix for me (and many others at the
time...Slydit.. you were in on this one) was to wrap tape around the bonnet
catch, it would last about 12 months a time, and wow what a world of
difference.
Making matters worse but to a much lesser extent, was worn bonnet hinges. To
fix this I added foam tape on top of all the bonnet stops front and back.
Good luck I hope this is your answer.
difference.
Re: annoying rattle 93 mx5
Check out the picture of the old POISON (1989 NA) in the MX5 POWER & POWER MOD SECTION. Hope the car does not rattle to bits with the bridgeport 13B. Must be time to change the tape.
The lucky winner was 'bonnet hinge" only rattled when i had the bonnet down, so a tricky burger to find, when searching. Have solved the problem temp. with a rubber sink plug (kiwi diy) bunged underneath the hinge. I think a trip to para rubber might be in order, unless i forget now the noise is gone LOL Cheers
Yes I think they are for sideways movement but adding some foam tape on them
works wonders.
works wonders.
