Koni Adjustables on TradeMe, also lowersprings and Style bar
Post by poison » Tue Feb 24, 2009 9:26 pm
Hey there is someone on TradeMe seeling Some Koni adjustables, some lowering springs, and a stainless style bar... yeah OK it's me...so check it out anyway
http://www.trademe.co.nz/Members/Listin ... mber=42675
More stuff to come over the next few weeks as I'm doing a cleanout.
Gravelben
Post by Gravelben » Wed Feb 25, 2009 3:53 pm
Why do these things always come up when I can't afford it! :cry:
Post by poison » Wed Feb 25, 2009 6:26 pm
Where's the passion, the dedication, surely you have a wife or kid you can sell? If not I've heard organ doning can be worth a bob or two.
marinerbluemx5
Post by marinerbluemx5 » Mon Apr 20, 2009 7:54 pm
Might as well shamelessly bump this thread :D I'm selling my suspension setup too (and the MX5, separately)...
Similar to the thread title, full details here:
http://www.trademe.co.nz/Browse/Listing ... =214310492
http://www.mx5forum.co.nz/ads_item.php?id=98
Oh and a lip spoiler too :shock:
http://www.trademe.co.nz/Browse/Listing ... =213220220
Post by WideOpenThrottle » Mon Apr 20, 2009 8:18 pm
Hi pioson & marinerblue
How many k's you guys have done on the suspension?
marinerbluemx5
Post by marinerbluemx5 » Mon Apr 20, 2009 8:39 pm
WideOpenThrottle wrote:Hi pioson & marinerblue
Me about 15,000 km.
My Eibach springs and Ground Control perches I bought new. So total about 15,000 km.
My Koni shocks, FM shock mounts and bump stops I bought from a good fellow from our forum here - jif (http://www.mx5forum.co.nz/profile.php?m ... file&u=109). He said he did less than 40-50,000 km on them. So total less than 55-65,000 km.
Post by poison » Mon Apr 20, 2009 10:13 pm
I'm guessing up to 5000 as I only did 8000 in the whole time I owned the
car.
Post by WideOpenThrottle » Tue Apr 21, 2009 9:39 am
Hi poison -no listing on trademe?????
Post by zorruno » Tue Apr 21, 2009 9:46 am
WideOpenThrottle wrote:Hi poison -no listing on trademe?????
His listing was in February...
Post by poison » Tue Apr 21, 2009 12:53 pm
A couple of people had asked me to hold onto them until they got the cash,
so I didn't relist... but time flies so first up with $600 owns them. Set
of Koni adjustables less than 5000k and repainted (fully stripped first) as
they got scratched and I'm fussy.
Gravelben
Post by Gravelben » Tue Apr 21, 2009 8:20 pm
Are there any issues using Konis with standard springs? Tempted but not sure that I want my car any lower than standard.
marinerbluemx5
Post by marinerbluemx5 » Tue Apr 21, 2009 9:11 pm
Gravelben wrote:Are there any issues using Konis with standard springs? Tempted but not sure that I want my car any lower than standard.
I know there's issues with the opposite case - aggressive springs with stock shocks, wears out the shocks prematurely. But the Konis with standard shocks... should be OK... one issue I can think of would be that a soft spring will go through the full suspension travel too easily, causing you to hit the bump stops. But if that's not something that's an issue now, then changing from stock shocks to Koni shocks probably won't worsen that tendency.
For the ride height issue... there's three perches on the Konis, so you can do a rough ride height adjustment that way. Set it to the highest perch and I think even with non-stock springs you may be able to get really tall ride height :D
Post by poison » Tue Apr 21, 2009 11:57 pm
My two cents. Agreed, the koni shock is designed for standard springs, that
said going a little firmer on the spring would be good for added cornering.
Too much spring rate (harder springs) will cause the car to become lively or
bouncy as the dampening of the shock is not enough to control the spring.
Much like having a worn shock as the shock no longer provides enough
damping.
If the shock has too much damping for a spring then the car will lose
traction on bumps as the shock will stop the spring from pushing the wheel
back to the ground. Shocks and springs must match, they should also match
the road and comfort requirements.
The stock spring rates F/R are roughly 165/100 lbs for the NA and 165/120
for the NB (correct me if I'm wrong) I had some 335/280's on some matched
Bilsteins and they were amaizing cornering but a little on the hard side for
comfort. I think it would be fine to fit Konis' with 220/140 if you want to
retain the NA F/R ratio. Or maybe 220/160 on an NB.
Sorry for typos etc, it's late and I'm rushing this.
marinerbluemx5
Re: Koni Adjustables on TradeMe, also lowersprings and Style
Post by marinerbluemx5 » Wed Apr 22, 2009 7:21 am
^ good post
poison wrote: The stock spring rates F/R are roughly 165/100 lbs for the NA and 165/120
found this list somewhere a while back, forget exactly where, think it might have been miata.net
Stock Springs: F 2.8 kg/mm, R 1.7 (F 154 lb/in, R 94)
King Springs: F 3.6 kg/mm, R 2.2 (F 200 lb/in, R 122)
Racing Beat: F 4.0 kg/mm, R 2.2 (F 226 lb/in, R 122)
FM Springs: F 5.7 kg/mm, R 4.2 (F 318 lb/in, R 233)
Eibach Pro-Kit: F 5.2 kg/mm, R 3.6 (F 292 lb/in, R 200)
Spec Miata: F12.5 kg/mm, R 5.8 (F 700 lb/in, R 325)
Post by Euen » Wed Apr 22, 2009 9:47 am
Thanks Marinerblue, I was wondering what the rate was on my old Kings. Kings do not actually publish the rate for their lowering springs, only for their special competition springs. Those rates do explain a lot.
I'm now running 400/250 on my current Konis and have had to wind the rebound damping to full on the rear to compensate for the higher spring rate.
PS: I have a surplus set of King lowering springs for an NB if anyone is interested.
