Rattle can jobby
Rattle can jobby
Post by chris » Wed Jul 18, 2012 10:18 am
Anyone used a rattle can to paint the car? O.o
I just got my baby resprayed, and dad wants his done, so we were going to do his at home.. I am going to try the headlight cover first, obviously I'll take my time with prep, but I am going to try a rattle can and see how it goes...
Anyone tried it? And don't knock it. It is an idea, and the paint is pretty ass anyway!
Post by WideOpenThrottle » Wed Jul 18, 2012 10:25 am
you might do it but you would need enough cans to successfully complete each panel at a time all pre-shaken!
Post by chris » Wed Jul 18, 2012 10:29 am
I'll see how just the head light cover goes :) I might do it in a bright yellow :3
I mean, chances are I'll get a gravity feed spray gun anyway haha
Rattle can jobby
Post by jif » Wed Jul 18, 2012 10:52 am
tried this on the hardtop (BRG, yurgh...) and it looked fairly good I thought, although it did tend to leave slight rain trails afterwards.
Post by chris » Wed Jul 18, 2012 11:02 am
Cheers for the reply! :) I was going to take a while doing each panel properly :) No need to hurry, so hopefully I can avoid any drips
Post by Born_disturbed » Wed Jul 18, 2012 11:26 am
Make sure you prime it and scotch bright/sand it properly, Prepsol the surface before any paint or primer hits it (Prepsol is a wax and grease remover)
You want thin even coats to build up a couple of layers allowing drying time between each layer and then make sure you clear it if you want it to look half decent.
The more paint layers you built up the easier it is to polish up and remove imperfections before clearing, just don't over do the paint layers or it will probably all go horrible eventually. Same deal with the clear, build up the layers so you can buff out any small runs etc just don't over do it
Post by punkoutnz » Wed Jul 18, 2012 11:31 am
Tried this, it's so damn hard to get it looking right. The cans just don't have a big enough spray pattern and it's really hard to get a good overlap. I have a gravity fed spray gun that I've had about a million times more success with than spray cans.
Post by chris » Wed Jul 18, 2012 11:32 am
Born_disturbed wrote:Make sure you prime it and scotch bright/sand it properly, Prepsol the surface before any paint or primer hits it (Prepsol is a wax and grease remover)
That's the way I was thinking too! Plus I am starting with the head light cover, so if I screw it up, not to much damage was done :P
Still need to decide on a colour
Post by Born_disturbed » Wed Jul 18, 2012 11:36 am
I would suggest rainbow but that might be a bit advanced, so maybe Pink?
Post by chris » Wed Jul 18, 2012 11:38 am
Rainbow would look hilarious!
bearing in mind I am only trying it on the headlight cover Punkout
I'll see how it turns out, chances are it'll turn out rubbish.
I will defo give the old boy some JDM rising sun though ;)
Post by Mr. Shine » Wed Jul 18, 2012 3:32 pm
My experience with rattle cans is that they're fine on smaller panels, but larger panels are a pain in the ass for the reasons punkoutnz mentioned.
Post by chris » Wed Jul 18, 2012 3:35 pm
Makes sense! Well, the paintjob can't get any worse!
Post by Born_disturbed » Wed Jul 18, 2012 4:17 pm
last_resort14
Post by last_resort14 » Wed Jul 18, 2012 5:05 pm
I think you could do a pretty sweet job with spray cans if you took your time.
My only suggestion would to be remove the boot and bonnet and do them standing vertically cos spray cans don't like to spray on much of an angle.
dynofiend
Post by dynofiend » Thu Jul 19, 2012 7:58 pm
Here's the thing. You can get a reasonable finish with rattle cans, but, it wont be as good (looking or durable) as if you used a spray gun, and by the time youve bought enough primer, and top coat, you may as well have bought some 2 pack, a gravity gun, and borrowed a compressor.
Post by Mad Kiwi » Thu Jul 19, 2012 11:45 pm
Absolutely agree with dynofiend.
Post by chris » Fri Jul 20, 2012 4:22 pm
After a bit of reading I have to agree and scrap my thread :P
Time to buy a gravity feed!
