Long time listener, first time caller.
Blaster
Post by Blaster » Sat Jun 23, 2012 1:09 pm
I'm what you might call a car guy. I always have been and I can't imagine changing.
I bought my MX about about a year ago. It was then that I started reading this forum. I've stalked the classifieds and considered buying plenty (Keith's gear mainly).
Note considered, but I'll get to what I've done soon.
I bought the car off a friend who bought it locally off a guy that seemed legit. My friend bought it remotely (mining in Aus) when he got to know the car he was bitterly disappointed. The PO either lied or had no idea (he owes or owned an Evo rally car so I doubt the latter). My friend went on to buy an NZ new ne with 90km on the clock and I got this one at a good price.
Mine (Blaster - my first car not called The Flying Fist of Judas) is pretty close to stock. It has some stiff after market springs (unknown brand) and a nicely laid out set of headers. I've added a set of semi sealed headlights with H4s and replaced changed the diff and gearbox oil to red line.
I work in Invercargill and live in Dunedin, making the trip weekly. Being a car guy I consider this a perk of the job. In the 2.5 years I've done it I have never not enjoyed the drive. I've done it in many cars, last most noteworthy was a Fiat 124 Sport (CC model) which was actually amazing. As they do, it gave me grief and after my third break down on a back road, I made they change to Blaster.
I'm rambling a bit so to cut short, I joined today to get some answers on some other threads. I thought I'd introduce myself at the same time.
Probably the most interesting thing you may find out about ne is that I am 2m tall and 105kg. Yes, I've almost stripped all the foam from the seat as well as removed a lot of the interior to be able to see and close the door. Its a laugh but still the best car I've driven through the back roads. I've toyed with driving with no seat at all (feels great parked, but I can't imagine it staying that way for 2hrs the way I drive).
I'll let you guys ask otherwise, I'll lurk around as long as I have Blaster (I change cars around every 18 months).
Regards,
Tim.
Post by Furai » Sat Jun 23, 2012 2:43 pm
Good to see another tall person in one of these great machines, Im 18 and 195cm so not quite your height or build(Im pretty skinny) but I found a spacer on the wheel helps alot.
You might want to have a look into Elise seats or buckets though.
Blaster
Post by Blaster » Sat Jun 23, 2012 5:06 pm
Yeah, I have been looking for a better option for seats. For right now, I'm happy. I never thought to space the wheel out. How did you go about it?
Post by Furai » Sat Jun 23, 2012 5:52 pm
Spacer works if you have a wheel that adapts with a bosskit, I went for a 20mm. Some come with the longer bolts some dont. Check out Moonlight Racing (MLracing.co.nz I think) they have some HKB ones.
Post by WideOpenThrottle » Sat Jun 23, 2012 5:56 pm
Blaster wrote:Yeah, I have been looking for a better option for seats. For right now, I'm happy. I never thought to space the wheel out. How did you go about it?
You could also fit a quick release to your steering wheel they will add up to 60-odd mm plus be a theft deterent.
Post by siren676 » Sat Jun 23, 2012 6:33 pm
That is a brilliant option for tall people, might consider one for mine though im only 190cm and a 68kg :lol:
Post by Furai » Sat Jun 23, 2012 7:55 pm
68Kg?? Need a few more pies bro to catch up to my 85Kg :lol:
Post by siren676 » Sun Jun 24, 2012 12:28 am
Its weight saving for racing season :lol:
Post by SLYDIT » Sun Jun 24, 2012 8:55 am
i had a BC 124 coupe (actually i had 3) until i saw the light and bought something reliable.
you could try a flat bottom sportline wheel. it may give you a bit more room
Blaster
Post by Blaster » Sun Jun 24, 2012 11:52 am
Line of sight is my biggest problem. I've removed the sun visor but still have to bend my neck to see. I've been reading about seat options but haven't settled on what is best.
r3spct
Post by r3spct » Sun Jun 24, 2012 12:49 pm
Im 6'3 and about 103kg, i just did the "foamectomy"mod to the drivers seat. Sit a lot lower, def a improvement. Looks like the steering coloum could be modified to be about 10mm higher with a bit of work.
Im debating removing the drivers side sunshade, it is in the way a bit.
Ive also removed the drivers side door handle and put a strap on, lots more room, but i do find i dont have anywhere to rest my elbow, aparently there is a earlier mazda 323 with a handle that doesnt have the front part of the the handle going up that gets in the way, but still lines up with the other 2 holes.
Zadkiel
Post by Zadkiel » Wed Jun 27, 2012 7:57 pm
I removed the door handle too, gave a fair bit more room for my knee. What did you do for the strap?
Post by authentic » Wed Jun 27, 2012 8:01 pm
Reading this makes me happy to be under 6ft :D
r3spct
Post by r3spct » Wed Jun 27, 2012 9:53 pm
I used a piece of 25mm webbing and just screwed it onto holes with suitable screws. worked fine but looked huckory, and was odd not having a arm rest. Got a 323 one from pickapart, think it was off a rear door, lined up with lower 2 holes perfect and looks the part.
Zadkiel
Post by Zadkiel » Tue Jul 03, 2012 6:05 pm
Do you think the otherside's arm rest is still there? :)
r3spct
Post by r3spct » Tue Jul 03, 2012 7:24 pm
Was prob 4 there, think front and rear are the same, only reason i got a rear one is it was already sitting on rear seat as someone had taken door trim off.
Zadkiel
Post by Zadkiel » Thu Jul 05, 2012 5:47 pm
Which Pick-a-Part?
r3spct
Post by r3spct » Thu Jul 05, 2012 10:56 pm
Avondale.
http://static.cargurus.com/images/site/ ... 17737.jpeg
this shape, but was a wagon
