General MX5 Chat
Post by MrGrey » Mon Sep 02, 2013 7:00 pm
After work today I popped the cam cover back on (as well as my lead cover of aesthetic pretty pointlessness) and it looks pretty swish. :) When I went to put on the air return valve at the front, I noticed that the pipe had split at the end that attached to the cam cover (it was 23 years old and the last 2 inches of the rubber pipe had hardened somewhat) so I nipped down to supercheap and grabbed one of these:
I gave it a run and have seen no leaks so far, so seems things went fine :)
Post by Furai » Tue Sep 03, 2013 2:36 pm
Soooo finally got her all fixed up.
Basically the engine wasnt worth fixing after the sump plug dropped out on the motorway and she seized. It sucks but the good new is the head is okay and I have a new more powerful engine.
So the engine I went for is an NB6C B6-ZE, I went for it as it would be easy to drop in, decent price, low Kms(60,000Kms), and it has solid lifters/higher lift cams which net an extra 10 odd PS.
So It all went in and the timing gears are different so I stuffed up the timing but finally figured it out and now its sorted and running beautifully.
So got everything tested and after a week went out to the first Drift day in a month!
Was my first time with the new engine and also drifting on the new Silk Roads with the 12/10K spring rate.
As you can see much less roll and much more control. As I hadnt drifted for some time and it was a new setup it took a bit to get used to and the suspension still needs some adjustment.
And here is a little video, Had fun chasing everyone. Was just trying to take it easy and keep temps down on tyres and motor. Might have to increase the rake a little as it wasnt quite turning in enough.
http://youtu.be/kZWeXNQGAjM
So Im happy she is going! I have a drift day every weekend this month so hopefully there will be some more videos and my driving should hopefully improve a bit as well as the cars setup!
NicF
Post by NicF » Tue Sep 03, 2013 2:45 pm
Love that exhaust
Post by chris » Tue Sep 03, 2013 3:04 pm
Good to see you're back out there!
TROLOL lives.
And my new engine arrives soon...
Post by MrGrey » Tue Sep 03, 2013 5:45 pm
great photos :)
@ Furai - I'm really stoked that things are finally coming together for you, I would hate to have my engine crap out on me like your did, but at least some of it is salvageable so it wasn't a complete loss.
@ Chris - nice to see trolol working again as well, I was gutted for you when she spat the dummy, I am glad you decided to keep her.
just to keep the photo sharing going, here's how my cam cover looks at the moment:
Post by Furai » Tue Sep 03, 2013 5:50 pm
MrGrey wrote:great photos :)
Cheers man, been thinking about building it up with 4AGE 92 Pistons and making a 1.7 :twisted:
Post by CordedBowl » Tue Sep 03, 2013 6:07 pm
@Furai, just put a full Blacktop 4AGE in there :twisted:!
Post by SkilletKid » Tue Sep 03, 2013 7:06 pm
Softies.
F20C
=P
Post by Furai » Tue Sep 03, 2013 8:28 pm
Weak. 26B is the only conversion or 20B if you want to be more subtle.
Post by SkilletKid » Tue Sep 03, 2013 9:00 pm
:P :lol: :P
Post by authentic » Tue Sep 03, 2013 9:56 pm
Decided to give it a wash since it was sunny...but now I can see swirl marks :(. Time to buy a polisher and get to work with a few stages of pads and compounds.
Post by marcellarius » Tue Sep 03, 2013 10:04 pm
:( they show up badly on dark colours. Looking good though.
Post by authentic » Tue Sep 03, 2013 10:28 pm
They were there since I've had the car, but I forget about them when its hardly ever sunny and the cars always dirty during the winter. With the right gear they shouldn't be too hard to get rid of.
Post by dylann » Wed Sep 04, 2013 4:01 pm
Going to be living down a gravel road soon, yay for drifts but will be having a dirty car 24/7 haha.
Post by MrGrey » Wed Sep 04, 2013 5:15 pm
Just watch out for tanker drivers Dylann :)
Remember the road rules of country roads:
"That which is biggest has right of way" :wink:
Post by brownie » Wed Sep 04, 2013 10:55 pm
[quote="Furai"]Soooo finally got her all fixed up.
If you don't mind ,what was the bits that needed sorting to make it work ?
Is just a matter of running NA timing gears ?,i know they run the same cambelt kit.
Kinda assumed it wasn't that easy,could be good to be wrong,got a couple of low km 1600's at work
Post by Furai » Wed Sep 04, 2013 11:01 pm
brownie wrote:
Furai wrote:Soooo finally got her all fixed up.
You only need to attatch the CAS sensor key to the camshaft thats it, the timing gears are slightly different but do the timing correct per engine manual you will be sweet. ;)
Post by marcellarius » Thu Sep 05, 2013 12:20 am
I do wonder whether it still makes the same power when using the NA6 ECU... The NB6 could be running different fuel and timing maps. Probably not a huge difference though.
Post by Furai » Thu Sep 05, 2013 7:22 am
marcellarius wrote:I do wonder whether it still makes the same power when using the NA6 ECU... The NB6 could be running different fuel and timing maps. Probably not a huge difference though.
Theres definitely more power but having higher lift cams it would no matter the ECU, the economy is better and the power increase is easily noticeable.
You probably wouldn't gain the full 10PS but close to it, Ill do another 0-100 run and see how much faster she is.
mazline
Post by mazline » Thu Sep 05, 2013 1:20 pm
Did you change the actual cam ,or does the end of the cam remove,had a look around here and looks like the whole cam needs changing ??,Can't see a removal piece for the key for the CAS to lock into.
Post by Furai » Thu Sep 05, 2013 1:44 pm
mazline wrote:Did you change the actual cam ,or does the end of the cam remove,had a look around here and looks like the whole cam needs changing ??,Can't see a removal piece for the key for the CAS to lock into.
We cut it off the NA6 Cam and put it onto the NB6 cam.
The other thing I forgot is you need to use an NA8 Alternator as its a different belt but I havent changed mine yet...
Post by SLYDIT » Thu Sep 05, 2013 1:49 pm
do you have to grind a slot in the NB cam? does the cas mount on the same side as the 1600 or on the other side like an 1800??/ pics please. :)
mazline
Post by mazline » Thu Sep 05, 2013 2:50 pm
This might be a good one to start a new thread in the engine section,could be useful information that is easy to find.
Post by Furai » Thu Sep 05, 2013 4:43 pm
Ill do that now :wink:
Post by BRM » Thu Sep 05, 2013 9:01 pm
Got my nuts & bolts back from electroplating,
Mazbro 2-way is ready to go together tomorrow,
Shit's painted black,
So excite.
Users browsing this forum: Bing [Bot] and 18 guests
