I gave it a run and have seen no leaks so far, so seems things went fine
Cheers man, been thinking about building it up with 4AGE 92 Pistons and making a 1.7MrGrey wrote:great photos
@ Furai - I'm really stoked that things are finally coming together for you, I would hate to have my engine crap out on me like your did, but at least some of it is salvageable so it wasn't a complete loss.
You only need to attatch the CAS sensor key to the camshaft thats it, the timing gears are slightly different but do the timing correct per engine manual you will be sweet.brownie wrote:Furai wrote:Soooo finally got her all fixed up.
So the engine I went for is an NB6C B6-ZE, I went for it as it would be easy to drop in, decent price, low Kms(60,000Kms), and it has solid lifters/higher lift cams which net an extra 10 odd PS.
So It all went in and the timing gears are different so I stuffed up the timing but finally figured it out and now its sorted and running beautifully.
If you don't mind ,what was the bits that needed sorting to make it work ?
Is just a matter of running NA timing gears ?,i know they run the same cambelt kit.
Kinda assumed it wasn't that easy,could be good to be wrong,got a couple of low km 1600's at work
Theres definitely more power but having higher lift cams it would no matter the ECU, the economy is better and the power increase is easily noticeable.marcellarius wrote:I do wonder whether it still makes the same power when using the NA6 ECU... The NB6 could be running different fuel and timing maps. Probably not a huge difference though.
We cut it off the NA6 Cam and put it onto the NB6 cam.mazline wrote:Did you change the actual cam ,or does the end of the cam remove,had a look around here and looks like the whole cam needs changing ??,Can't see a removal piece for the key for the CAS to lock into.
