G4 PNP Issues - Update:New Help Required!
Post by Born_disturbed » Thu Jan 29, 2015 12:48 pm
Question for yall:
I have a BP from a 97 NA SR Limited that I dropped in DEFCTV a few years back and im now going over to the G4 PNP.
Now at the time I went the lovely route of redoing all the wiring and fiddling with it until it worked. No easy task but I got there after studying wiring diagrams for what seemed like months. Which means I currently have the OBD 1.5/2 wiring for the ECU making PNP a no go.
I have reacquired a full set of looms to swap back to the early 1.6 setup however I’m wondering what else I may need to fiddle with to get it all working (NA for now)
It has no EGR equipment on it from stock, so basically my main concerns would be the Throttle body and coil setup as normally when people 1.8 swap they keep the 1.6 gear?
Anyone have any insight on this?
Last edited by Born_disturbed on Sun Feb 15, 2015 11:21 pm, edited 2 times in total.
Post by WideOpenThrottle » Thu Jan 29, 2015 4:25 pm
2low2c
Post by 2low2c » Fri Jan 30, 2015 7:17 am
the easiest and cheapest way in the long run would be to ditch the factory loom and use a atom or storm wire in ,i can wire it up for you if you want .
Post by SLYDIT » Fri Jan 30, 2015 6:59 pm
so the g4 pnp is for a 1600 loom and you have a 1600 loom?? whats the issue?
Post by SLYDIT » Fri Jan 30, 2015 7:05 pm
does this help?
http://www.miataturbo.net/megasquirt-18 ... 208/page6/
from memory the pins in the loom plug can be removed and moved around if required
Post by Born_disturbed » Sat Feb 07, 2015 6:50 pm
SLYDIT wrote:so the g4 pnp is for a 1600 loom and you have a 1600 loom?? whats the issue?
Issue is im using an 1800 engine, few differences between them
Post by Born_disturbed » Tue Feb 10, 2015 3:06 pm
Progress was made, sliced my finger open before I could finish.
Hopefully get it all sorted next weekend
Post by Born_disturbed » Sun Feb 15, 2015 11:19 pm
Okay, progress has been made
Engine will start and idle when cold but only if the master fuel is above 40, idles best at 50 which is max, any less than that and it will idle for a few seconds then die.
Once warm it wont start at master fuel of 50, will at 40 but dies after a few seconds and same for lower numbers.
When it is idling hitting the gas kills it instantly.
IAT/AFM/TPS all disconnected and turned off, everything in the tables looks correct.
Full NA6/1.6 looms with associated bits (ignitor, relays etc) 1.6 coils, 1.8 injectors, 1.8 CAS.
Any thoughts?
Post by siren676 » Sun Feb 15, 2015 11:55 pm
Sounds like something to do with cold start or crank enrich.
Have you got a wideband hooked up?
Post by Born_disturbed » Mon Feb 16, 2015 12:19 am
No wideband, and is set to no wideband
Doubting it is cold start as we are totally unable to rev the engine at all without it dying, unable to check properly due to no wideband obviously just working off changes in the fuel table
Post by siren676 » Mon Feb 16, 2015 7:58 am
My wideband isn't in use at the moment if you want to borrow it
Post by CordedBowl » Mon Feb 16, 2015 8:29 am
What tps are you using?
2low2c
Post by 2low2c » Mon Feb 16, 2015 8:53 am
which ecu are you using , where is the map sensor hose running from?
Post by Born_disturbed » Mon Feb 16, 2015 9:01 am
Thanks Dan, might take you up on that offer.
TPS is not currently connected
ECU is a G4 MX5 PNP with V1.2 board
Map sensor has its line run from the intake mani roughly between cyl's 2 + 3 and is not shared with anything else
Post by Born_disturbed » Tue Feb 24, 2015 10:44 am
Issue turned out to be not having an AFM connected, requires a signal from the open flap to trigger more voltage to the fuel pump. Jumped the 2 pins and it running.
Now to tap in a water temp sensor for the fans and fix the now failed water pump :/
Going to do the timing kit at the same time and, if I can sort some, I will upgrade the cams and get some adjustable cam gears too
But she drives! and drives well so I am happy.
built4speed
Post by built4speed » Tue Feb 24, 2015 10:00 pm
Born_disturbed wrote: Now to tap in a water temp sensor for the fans and fix the now failed water pump :/
So do you have a water temp sensor hooked up for cold start etc? If so why dont you use the link to trigger the fans?
Users browsing this forum: Bing [Bot] and 4 guests
