by Junkwhale » Sat Mar 08, 2014 1:55 pm
^^ nice. prob wanna look into some wider tyres to deal with that extra hp
by BRM » Sat Mar 08, 2014 7:05 pm
Whut...
That's not how you upgrade brakes.....
paint?...
by Angreal » Sat Mar 08, 2014 7:20 pm
BRM wrote:....
Whut...
paint?...
Thermal capacity
by MrGrey » Sat Mar 08, 2014 8:43 pm
by GRUVBB » Sat Mar 08, 2014 8:59 pm
Looks like the clay bar has done a good bringing up the shine...... Is it a pleasure to use or what?
I see you have also got some White Supercats
Lucky I went with the 25 KW Red.
by MrGrey » Sat Mar 08, 2014 9:27 pm
yeah, I started to do them, but decided to leave it until I take the tyres off when I swap my suspension
DeeCee
by DeeCee » Sun Mar 09, 2014 7:31 am
Slave cylinder blew during the week. Replaced both master and slave as original parts 20+ years old.
by MrGrey » Mon Mar 10, 2014 3:02 pm
GRUVBB gave me his old rear garnish and after a bit of a fix it job and some wrap it came out looking pretty decent
by GRUVBB » Mon Mar 10, 2014 3:14 pm
Sweet Skills Wrap It Man!!!..... That is a true transformation from the relic lying on my deck the other day. Glad it came to use rather than going in the bin. The garnish MAZLINE supplied me was a much easier option for my requirement at the time.
mjrstar
by mjrstar » Mon Mar 10, 2014 6:29 pm
Cambelt
Then started on adding a birds nest to the engine and interior.
by MrGrey » Mon Mar 10, 2014 6:38 pm
awesome work! I would personally find wiring a car a rather daunting task.
by evel » Mon Mar 10, 2014 8:34 pm
mjrstar wrote:Cambelt
Why does the the valve cover look like a 4G63?
by REDBEN » Mon Mar 10, 2014 11:13 pm
evel wrote:mjrstar wrote:Cambelt
Because thats exactly what it is
by GRUVBB » Tue Mar 11, 2014 12:09 am
Its Always a pleasure to see a freshly painted engine bay when a fresh motor goes in. It definitely helps to set the look up front. Just another component of detail. Well done!
by Timmo » Tue Mar 11, 2014 9:15 am
You probably don't want to hear this after all that work, but you've put the wrong engine back in the car!
mjrstar
by mjrstar » Tue Mar 11, 2014 5:23 pm
^^ And gearbox / diff / lots of other stuff too.
McNuggetBandit
by McNuggetBandit » Tue Mar 11, 2014 9:39 pm
mmmmm put my freshly painted wheels on today nice and purple.... i like to stand out a bit......
紫色霧
1992 MX5 S SPEC Purple/Black
MattBRG
by MattBRG » Tue Mar 11, 2014 9:48 pm
After being overseas for a few weeks and then a while of deciding not to 'play' with my new car, ive decided to start to do little things.
started on changing the KG Works Cluster from the spare car, To Black rather than the wood-grain that it came with.
started with this:
then after a bit of a heat gun:
And then adding Matt Black Vinyl, if this doesnt work too well im going to paint a wrinkle finish.
Hopefully start on new door cards in the next week and get ordering my new Gauge faces!
Cheers Matt
by GRUVBB » Fri Mar 14, 2014 9:33 am
Fitted Hardtop and removed old window Banner.... Off to get a price for tinting of hardtop.
fooesboy
by fooesboy » Sat Mar 15, 2014 12:20 pm
Made some good progress on Seal yesterday thanks in a BIG way to MattBRG for all his help!
Fitted Würth sound mat to the floor and parcel tray
Installed the carpet and the dash
And the tow strap
Slowly starting to look like a car again!
by GRUVBB » Sat Mar 15, 2014 1:15 pm
Looking good FooesBoy!!! Hope you don't need that tow strap.
ps.. I love that cluster
fooesboy
by fooesboy » Sat Mar 15, 2014 11:12 pm
Started this cool little mod today...
Sanded off the raised markings that where holding the polish residue and they came up rather nice. Using wet n dry started with 350 then 600, 1000, 1500 and 2000. Still looked too dull for my taste even with a good polish so then pulled out the "Micro Mesh" at 3200, 6000, 8000 and 12000 lastly a final going over with some swirl remover.
I have just 1 rear brake light to finish before I fit them on.
And yes I know this one is chipped, this one is a spare that I used first to try it out... really didn't feel like stuffing it all up eh?
by MrGrey » Mon Mar 17, 2014 4:13 pm
very nice effort Fooesboy, they look much better. Myself personally I just painted the front ones black as you don't need them for a WOF (but you must have the red reflectors at the back) and after seeing how nice yours turned out, I am very tempted to give my rear red reflectors some similar TLC
Today I crawled out of bet at 3:30pm to get a WOF and discovered that my shiney new screws had arrived so after passing the WOF I put them in to replace the old slightly corroded OEM screws....
thank you GRUVBB!
now in the remaining time I have left I am going to make a start changing my suspension over (its all fun and games til someone skins a knuckle)
by GRUVBB » Mon Mar 17, 2014 5:07 pm
I have 2 more sets of steering wheel screws in stainless if anyone is keen on some. PM me if you are keen. Like the ones MrGrey has just fitted today as above.
by SkilletKid » Mon Mar 17, 2014 6:36 pm
MrGrey wrote: (its all fun and games til someone skins a knuckle)
It's not your car until you bleed on it. =P
Users browsing this forum: Bing [Bot] and 67 guests
