Braided clutch hose
DeeCee
Braided clutch hose
Post by DeeCee » Wed Mar 05, 2014 12:50 pm
Where can I find a braided clutch hose ?
I am about to change the master and slave cylinders and wish to take the opportunity to change the hose as well.
If available, how much ?
Post by BRM » Wed Mar 05, 2014 2:05 pm
Hi there,
I've got a stock one lined up to be copied when I have the.time.
Though I'm unsure if the generations have different lengths / fittings.
Post by SLYDIT » Wed Mar 05, 2014 5:58 pm
949 racing ..they do brake lines too for around the lowest price
Post by Angreal » Wed Mar 05, 2014 6:39 pm
SLYDIT wrote:949 racing ..they do brake lines too for around the lowest price
Is there a difference between lhd and rhd?
DeeCee
Post by DeeCee » Wed Mar 05, 2014 6:39 pm
Thanks for the info guys, I will follow up with 949
Post by SLYDIT » Wed Mar 05, 2014 6:46 pm
na as far as i know only the hard lines are different and they terminate at the same point so the flex is the same.
Post by WideOpenThrottle » Wed Mar 05, 2014 7:08 pm
Edited :D
Last edited by WideOpenThrottle on Thu Mar 06, 2014 4:09 pm, edited 1 time in total.
Post by marcellarius » Thu Mar 06, 2014 1:21 pm
From what I've read, the clutch hose can be a bit testing to get at with everything in the car. It's certainly not something that is "just there" when changing the hydraulic cylinders ;)
Post by evel » Thu Mar 06, 2014 5:04 pm
APPARENTLY american braided lines dont meet the requirements for a NZ cert. My boss at work who has imported a few bits (brakes and shit) from the states before told me this.
Post by marcellarius » Fri Mar 07, 2014 3:39 pm
The rules on this have flip-flopped a bit. I think now they've taken a sensible stance that if it's clearly designed as a brake hose and has crimped/swaged fittings (i.e. the fittings don't screw together onto the hose) then they meet the in service requirements (WOF)...
I don't think you'd run into problems over a clutch hose though.
Post by SLYDIT » Fri Mar 07, 2014 5:18 pm
I am very confident in using an American brake line. I mean imagine the law suite if one failed due to being sub standard.don't think the u.s suppliers would risk that.
Post by Snapfrozen » Fri Mar 07, 2014 10:03 pm
SLYDIT wrote:I am very confident in using an American brake line. I mean imagine the law suite if one failed due to being sub standard.don't think the u.s suppliers would risk that.
They contract out of liability :P Go with Bridgestone, no problems there
