Plugs for supercharged car
I have been running NGK BKR7E v-power plugs in my supercharged car, it runs 10psi.
One just went and died on me and I need new plugs. What are you turbo guys using and what gap at you running them at?
I am happy to buy the best plugs available if they will last a little longer.
hey Warrior... ran the NGK platinum plugs with the standard gap, 1 step colder on the turbo'd na8 ... no problems ever. A++ would buy again :)
On 4 February 2014 15:28, warrior <mx5talk@mx5forum.co.nz (mx5talk@mx5forum.co.nz)> wrote:
[Posted via external email]I have been running NGK BKR7E v-power plugs in my supercharged car, it runs 10psi.
I have them available at $23 each
Use the MX5FORUM code in the "how did you hear about us" box and get 10% off that. If the order is over $80 you get free delivery
http://www.broomfish.co.nz/product_info ... ts_id=2128
IIRC - smaller gaps are for where you'd have trouble sparking with a bigger gap. Iridium/platinum sparks more easily than regular plugs, so I'd not make the gap any smaller unless absolutely necessary.
If you're still running a wasted ignition (ie stock) one of each of the plug pairs will be firing backwards, so you'd really want the plugs with plat/Ir on both electrodes. eg PFR7A-11 , which ran flawlessly for the turbo. Stock gap is 1.1mm
Hope thats correct ... its been a while.
http://www.miata.net/garage/KnowYourCar/S2_Plug.html
Best plugs for the MX5 (and most engines) are
NGK Resistive BKR7E
Anything else is a waste of time and money - and won't work anywhere near as well.
Any decent turbo or supercharged car that comes in for tuning with platinum or similar plugs get changed first thing
Countless times I've have spark blowout or misfiring using platinum/Iridium plugs, that gets fixed right away by replacing cheap copper plugs.
Try and find a race team that doesn't use copper plugs, as they conduct better than anything
Best thing of all - is they are only about $6 each from SUpercheap
If you engine is chewing them out, then there's something else afoot.
NGK Resistive BKR7E
Users browsing this forum: No registered users and 90 guests
