HELP!!!!!
HELP!!!!!
Post by warrior » Sat Feb 01, 2014 12:49 pm
I finished putting in my wideband a couple of days ago and now the car wont run at all.
The car starts, runs VERY rough and backfires etc, It is more or less undrivable.
This is what I have done to try and solve them problem.
Taken wideband out and gone back to oem sensor, checked plugs, changed spark plug leads, checked for air leaks, disconnected the powercard that runs the fuelling for the supercharger (just in case it was over fuelling), put in another battery.
I have been working on this for two days now and cant get it sorted. It sounds like a air leak to me but I cant find one anywhere.
I don't think the problem had anything to do with the wideband as this has happened once or twice on start up before but did not last for long and I just put it down to a flatish battery.
HELP PLEASE!!!!!!
Post by SLYDIT » Sat Feb 01, 2014 2:41 pm
1) change your plugs even if they look ok.
2)unplug your ecu and plug it back in again to make sure the plugs are seated.make sure the ecu earths are ok and the ecu is bolted to the floor, not just sitting on it.
3)check your fuses. The ecu has at least two power feeds. You may have busted one installing the wideband or even your stereo could be screwing it up.
4)manually move your afm flapper to see if its moving freely.
5) check your hose to the power card unit.
its a possibility that you may have fried a coilpack if you were testing the wideband with the ignition on for long periods...
Post by WideOpenThrottle » Sat Feb 01, 2014 10:30 pm
One way to check for vacumm leaks :D
http://www.youtube.com/watch?v=9CPqbaSgcok
Post by warrior » Mon Feb 03, 2014 1:26 pm
I think I MAY have tracked the problem. I took the plugs out of the engine and tested the coils to to see if there was any spark from the spark plug lead connected to one coil then a plug in and earthing to the block)
It looks like (to me) there is a very poor spark coming from all the coils.
I will test my other mx5 when the wife brings it home to see what that one does but if there is very little spark coming from the coils would it be ALL the coils that are no good or should I look elsewhere?
I spose the easiest thing to do would be to swap the coils over from my other car to this one and see if it works?
Ideas guys????
Post by Snapfrozen » Mon Feb 03, 2014 7:18 pm
Check earths, check wires. Could be you shorted something or bumped an earth installing the wideband?
Post by warrior » Mon Feb 03, 2014 9:03 pm
Ok I feel stupid and happy at the same time now. I am not young youngish but not young and should have know better.
I have spent three days chasing this problem and it was a bad spark plug, it looked perfect but it was not.
A word to the wise, don't just check your plugs when you have a problem, replace them.
:oops:
Post by SLYDIT » Mon Feb 03, 2014 10:45 pm
Yup. Had EXACTLY the same issue once... Bad plug
