by MrGrey » Tue Jan 07, 2014 9:02 pm
Holy sock in the jocks batman! amazing cars!
nothing wrong with cellphone pics, but then again, I am a totally crap cameraman
thanks for sharing
by evel » Tue Jan 07, 2014 9:34 pm
you must go through a lot of pair of undies at work. amazing
by Furai » Mon Jan 20, 2014 5:22 pm
- I only think 5.
by warrior » Mon Jan 20, 2014 5:34 pm
How hard was it to fit the roll cage? I have one that I have get trying to get around to fitting. Did you lose much seat travel?
by Furai » Mon Jan 20, 2014 6:00 pm
Lost a bit of seat travel but it was custom made and welded in I helped they guy a little with holding things but thats about it.
Im 195cm and with the low bucket I still fit
by Angreal » Mon Jan 20, 2014 8:11 pm
You won't like my car as I keep adding weight
Does the bag over the power steering stop the oil spraying all through the engine bay?
by Junkwhale » Mon Jan 20, 2014 8:19 pm
Furai wrote:Lost a bit of seat travel but it was custom made and welded in I helped they guy a little with holding things but thats about it.
What seat is that? Looks good in the matching tan...
by SLYDIT » Mon Jan 20, 2014 11:07 pm
Hey furai. I hope you replaced that bolt that holds the ac bracket to the block.it bolts through the oil pump hosing on the front of the block. You need to buy a shorter one or pack the old one with shit loads of washers
by Furai » Tue Jan 21, 2014 7:38 am
SLYDIT wrote:Hey furai. I hope you replaced that bolt that holds the ac bracket to the block.it bolts through the oil pump hosing on the front of the block. You need to buy a shorter one or pack the old one with shit loads of washers
Luckily I found out about it, didnt have one though so buying one this morning
by Furai » Tue Jan 21, 2014 7:39 am
Junkwhale wrote:Furai wrote:Lost a bit of seat travel but it was custom made and welded in I helped they guy a little with holding things but thats about it.
Its a re upholstered Momo T bucket
- I only think 5.
by warrior » Wed Jan 22, 2014 2:03 pm
Furai: have you have your car complied with the cage in? If you had did you have any problems getting it done?
by marcellarius » Wed Jan 22, 2014 4:16 pm
Angreal wrote:Does the bag over the power steering stop the oil spraying all through the engine bay?
It thankfully doesn't seem to 'spray' out but it definitely makes its way under the headlight, down the left side of the chassis, around the suspension, onto the track etc. when the car gets abused
by Snapfrozen » Wed Jan 22, 2014 8:44 pm
warrior wrote:Furai: have you have your car complied with the cage in? If you had did you have any problems getting it done?
It should be deemed a rollbar from an NZTA perspective so shouldn't need certifying. I believe if you keep it out of the "A" area of the car you're fine, which is essentially if you can sit there and touch it, it needs an authority card, if it takes up the "B" space of the car (rear passengers) it needs a cert.
This was how I understood it from my certifier when I spoke to him about it 6 months ago
by marcellarius » Wed Jan 22, 2014 9:21 pm
Yeah. The rules on this are somewhat inconsistent. I think from a WOF/cert-threshold point of view it needs to be completely behind a vertical plane at the back of the rearmost seats. If not, then
technically it needs certing. Some bar designs will be partially above the standard headrests... will you fail a WOF on that.. maybe not?
by Mr. Shine » Thu Jan 23, 2014 10:47 am
marcellarius wrote:I think from a WOF/cert-threshold point of view it needs to be completely behind a vertical plane at the back of the rearmost seats.
Correct me if I'm wrong, but from memory I think specifically it needs to be behind a plane drawn parallel to the back of the seats, doesn't it?
i.e. it needs to be behind a plane drawn something like / rather than like | if that makes sense.
by Furai » Thu Jan 23, 2014 1:36 pm
It clearly states,
" the bars are positioned:
behind, following a plane extending upward, parallel to the back of the backrest
on the rear-most seat; and
in such a way that the head-restraint would provide protection from head
contact with any bar section during a crash.
So for a rollbar that meets that no Cert is required.
by marcellarius » Thu Jan 23, 2014 4:24 pm
Mr. Shine: I think you're right, the diagram in the LVV interior impact standard agrees with that.
I'm not sure how those rules apply to seats with a fixed head rest like in the MX5, nor does it specify how the seat should be adjusted when determining the C-zone -- for the A-zone it's defined with the seat at its mid point in a normal driving position.
- I only think 5.
by warrior » Thu Jan 23, 2014 5:45 pm
I have been told the biggest problem with a roll cage in a mx5 is not the top part but the sides of the roll cage. That is wear peoples heads will hit in a side impact.
My roll cage looks just like yours furai and I would say someones head could easily hit the roll cage.
But not on your drivers side due to the seat you have.
I have a style bar in my car now and it has never been questioned in my car at WOF time so I am guessing the roll cage will be the same. (I hope)
by SLYDIT » Thu Jan 23, 2014 7:19 pm
roll bars in MX's that bolt to the floor are always going to be very suspect with regard to the "A" zone.. those designed like the brown davis and hard dog bars are better in this regard, although the hard dog styles will impede your seatbelt operation...for my car i am re-making a brown davis copy but with hard dog rear stays...its just a trackday/autocross bar so no need for full MSNZ bullshit regs
https://www.facebook.com/photo.php?fbid ... =3&theater
hopefully the pic shows for you non facebook users..let me know if you cant see it
by Furai » Sat Feb 08, 2014 9:24 am
Went to a trackday on Thursday, had a good bit of fun. Realised that Yoko A drives are good but no where near good enough for track. So I had to put my S Drives back on to get some grip.
The A drives snapped real fast Haha
Got a short video of me pushing fairly hard
http://youtu.be/--Bijpppi-I
by MrGrey » Thu Mar 27, 2014 5:50 pm
I went down the shops before work and had a middle aged gentleman ask "what sort of car is this? its beautiful.... or should I say, what sort of car did this used to be?"
I must admit that it bought a smile to my dial
by Snapfrozen » Sat Apr 05, 2014 11:29 am
Guess I can't prolong that engine swap anymore...
by MrGrey » Sat Apr 05, 2014 11:44 am
oh man, I am genuinely sorry mate
by marcellarius » Sat Apr 05, 2014 12:18 pm
Where did the oil come from?
by Snapfrozen » Sat Apr 05, 2014 12:29 pm
At this stage, no idea... Spark plugs are clean, so are under the leads, appears to be from intake side of block/head...
Users browsing this forum: Bing [Bot] and 21 guests
