Water pump?
Water pump?
Just changed the radiator fluid etc and now it is leaking fluid, I think it may be the water pump. Is this common when the car is getting on a bit? How can I tell if it is the pump?
Where is the best place to get a new water pump from and what else should I do while the parts are apart?
Water leak
When i changed my thermostat on purchase I found that my new gasket weeped for a couple of weeks. It has since stopped. Good news for me but does not help your situation probably.i would have thought that a dodgy pump would only leak back into itself. Maybe the faces are pitted or gasket is failing. Have not pulled m y pump out yet will do that when cam needs attention or a surprise birthday.
Best place i know of is http://www.broomfish.co.nz/products_ymm ... ars&page=1
You will need to take the cambelt off again to get to the water pump
Hey warrior, those prices by broomfish are pretty good unless you can get trade price from repco.
I would recommend that you go with the gmb one as they are meant to have better castings and mine came with 2 gaskets and an o-ring.
It's not an overly difficult swap, just time consuming.
I just did mine yesterday and it took a few hours.
Any questions just ask
She's definitely a big ol' job, used the same technique as above to keep cams in place. Just make doubley sure they don't move as you wrestle on the cambelt, took us a few goes to get everything lined up.
That first start up after is definitely a good feeling haha
'96 Celica - Because DD
Users browsing this forum: No registered users and 58 guests
