NA6 exhaust gasket and flange gasket part number needed.
Wickmyster
Post by Wickmyster » Sun May 26, 2013 8:33 am
I have been though the ACL catalog and there are two exhaust manifold that come up, neither for the MX5 specificaly, ad they are both slighty different.
Then I found the part number for the flange seal/gasket anD I sawe it was only 1 7/8ths......that cant be right????
Any one know where to get one from (have not been able to get to Mazda during their opening hours), all the usual parts store are stumped....doesn't help that that parts people don't know what they are doing tho :/
Post by SLYDIT » Sun May 26, 2013 2:04 pm
pretty sure tha mazda part # for the manifold to head is :
B695-13-460A
the standard mx5 exhaust size is indeed 1 7/8"
ebay has heaps of parts. theres a vendor called "miatamecca" that has them for $30 shipped to your door
Wickmyster
Post by Wickmyster » Sun May 26, 2013 7:27 pm
Cool thanks for that.
Anyone bought an aftermarket one successfully?
From where?
Will give mazda a call tomorrow I think!
Post by authentic » Sun May 26, 2013 7:35 pm
Is this a header gasket, or an exhaust pipe gasket that you're asking about?
Post by WideOpenThrottle » Sun May 26, 2013 7:44 pm
Try and get them all in the stainless steel ones that are around and may be OE rather than the composite type ones.Longer lasting & re-usable.
Wickmyster
Post by Wickmyster » Sun May 26, 2013 7:53 pm
I am after the manifold gasket that goes agaisnt the head and the flange seal at the base of the headers.
Will ask about stainless one Thanks :D
Post by WideOpenThrottle » Sun May 26, 2013 8:24 pm
This [might] be the stainless gasket part #s
Wickmyster
Post by Wickmyster » Sun May 26, 2013 8:33 pm
Hmmm ok, so thats wat repoc mean by gasket set. $50ish, Might just try the flange seal first. I just have an exhaust leak in my engine bay and was going to do both to be safe.....
Post by authentic » Sun May 26, 2013 8:46 pm
Ah right. I was told that the OE gasket that is currently on there can be re-used if you wanted to. But I just went and got one from BNT. It was fairly cheap, but its one of those composite ones that is basically a one time use thing. As for the flange gasket, I took my exhaust into a nearby shop and just went through and tried which ones would fit. Only useful if you have your exhaust in pieces though.
Wickmyster
Post by Wickmyster » Fri May 31, 2013 9:19 pm
This is the part I want, but no one seems to have listed!
Users browsing this forum: No registered users and 68 guests
