Na big brake upgrade
Enth
Post by Enth » Thu May 16, 2013 6:04 pm
I need to replace the front rotors on my 1991 1.6l MX5. So I thought I'd do the whole 1.8l big brake upgrade.
As far as I've read all I need are the 270mm 1.8 rotors and the caliper brackets, right?
I'm trying to get genuine parts from Mazda, does any one know the part codes I could give them so they can put an order through for me?
On another note, what are good pads to use with this set up if I'm using the car as a daily but attend the occasional track/drift/ghymkhana day?
Cheers.
Post by SkilletKid » Thu May 16, 2013 6:37 pm
*snip* wrong thread sorry lol
Enth
Post by Enth » Thu May 16, 2013 7:59 pm
Found the part numbers to the caliper bracket on this site
http://www.bigllama.com/miata/brake/bigbrake.htm
NA75-33-291 - Front Left
NA75-33-281 - Front Right
NA75-26-29X - Rear Left
NA75-26-28X - Rear Right
Now just need the part numbers for the rotors.
Mikkels
Post by Mikkels » Thu May 16, 2013 8:08 pm
I recommend you get the correct springs that go between the pads to prevent rattles. I did the upgrade on my 1990 and the pad rattle drove me mad. Finally got springs and clips from a place in the UK. Problem solved.
Also you will need to extract the rubber inserts from the old brackets. These were hard to remove on mine. Finally succeeded by using a stiff piece of wire and CRC to carefully work around the outside to free without damage. They fit the new mounts
Don
Mikkels
Post by Mikkels » Thu May 16, 2013 8:11 pm
Oh yeah you need pads as well. The 1.8s are bigger.
Post by MrGrey » Thu May 16, 2013 10:27 pm
Very useful info guys, Thanks :)
I too, need to upgrade my brakes
Post by WideOpenThrottle » Fri May 17, 2013 8:16 am
I have NB rotors [255mm dia] and calipers [$50.00] on my fronts and they do just fine with EBC yellow race pads...no point going to bigger set-up and using standard pads!
Have heard Bendix ultimates are sufficient.
I have yellow EBC on the back as well and need to be warm /hot to work best so the downside is my handbrake doesnt work so well when cold.
Mikkels
Post by Mikkels » Fri May 17, 2013 8:28 pm
The 1.8 pads are bigger in area than the 1.6 so regardless of pad material you are getting bigger grip.
Post by Donovan » Fri May 17, 2013 9:50 pm
I have a front set of 04 NB Sport calipers and pads that can sell if interested, haven't got the rotors for them.
Post by WideOpenThrottle » Sat May 18, 2013 8:25 am
Mikkels wrote:The 1.8 pads are bigger in area than the 1.6 so regardless of pad material you are getting bigger grip.
Yeah for sure but i cant see any point in wanting bigger brakes and then only using standard pads...do it right and put in upgraded pads as well! :D
Users browsing this forum: Bing [Bot], Google [Bot] and 6 guests
