Leak 1;
I have intermittent water leaks onto passenger floor pan. Have not been able to track where originating from until I get to strip out seats and carpet etc.
I know about the drainage holes but would like to clarify a few points. I believes there are one either side of seat to drain water from soft top. These are clear as I regularly pass a flexy rod through them. The flappers were full of sludge originally.
I park on a hill facing downwards. I suspect that the reservoir catchment area fills up and overflows over the front lip as the car does not sit level. All the flow migrates to passenger side. The drain is located at the rear of catchment space and perhaps in the torrential downpours overflows before drain starts to divert down to ground level. (DIY diagnosis)
I have dug a new car park space at home so car sits level but still on a slop.
Will try parking it on mechanic ramps to get car more level in all planes.
Leak 2. If I park with front of car elevated up hill it rains onto drivers right knee between soft top and rubber gasket on top of windscreen.
I have adjusted running thread on soft top latch to increase tension to no avail. Are these the latches that I recall someone saying can be rebuilt with inserting new plastic bush or something????.
I park facing downhill but the passenger floor pan then suitable for tropical fish rearing.
How tight should the latches be to secure efficiently without over stressing the roof fabric?
Do I then need to put ramps at rear of car when parking.
I have checked that drainage holes intop windscreen rubber are clear by pushing silphos stick through them. They are not ripped or blocked.... Are they supposed to have those holes in the rubber? They look genuine.
Leak 3;
Once again with heavy rain I sometimes get a wet seat.( not a good look if going on a date).
Once again I suspect the leak could either be from the crease where soft top folds. It is slightly worn for approx 30 mm.... Sorry unable to load pics to demonstrate hence the verbal diarrhoea explanation.
The rubber seal is sectional to allow for folding. Where they meet with a sort of mitred finish is where the water appears to come from.
Of course when I put the hose on the car nothing is evident.robably going to strip out seats and carpet and check things out once weather improves. I no longer have a garage...
The rubbers all appear intact and flexible.
Any ideas would be greatly accepted. Sorry about long spiel but wanted to document all that I had checked with my ever increasing knowledge to avoid being told to check things I already have.
