How hard is it to replace the side mirrors?
Post by MrGrey » Mon Feb 04, 2013 4:10 pm
yet more questions from me :P
my car came with (what I assume) are aftermarket mirrors and I was contemplating replacing them at some point with original style mirrors.
how hard are they to replace?
any tips, tricks or pointers you could mention for mirror replacement?
thanks in advance for your feedback :wink:
Post by chris » Mon Feb 04, 2013 4:13 pm
HAHAHAHAHAHA YOU ARE SCREWED THEY ARE GLUED ON.
Sorry - they should be fairly easy :) The Stock ones are 2 screws, see if you can get the cover off.
Post by MrGrey » Mon Feb 04, 2013 4:22 pm
you bugger, you had me with that first line....
my initial response:
http://www.youtube.com/watch?v=umDr0mPuyQc
Post by chris » Mon Feb 04, 2013 4:24 pm
I'm glad I did ;)
Okay serious response. It looks like the black cover (possibly a cover) can be flipped off with a screwdriver.
ross
Post by ross » Sun Feb 10, 2013 12:53 pm
Easy to replace.Flip back the cover and unscrew.
Make sure you use a no3 Phillips screwdriver as heads are machine screw heads are bigger than standard.
No need to remove the inner panel as nuts are welded inside the door shell.
If you need standard mirrors I have them.
Post by MrGrey » Sun Feb 10, 2013 5:29 pm
if you have a spare set of standard mirrors for an NA6 then I would be interested....
how much would you be after for a pair?
