malcster
Post by malcster » Tue Jan 29, 2013 10:29 pm
REDBEN wrote:
Euen wrote:Have a talk to Kayne. He may be able to adjust the clutch set-up on it (assuming you want to keep it) to make it a bit smoother. He set up my OSG and it is great.
Ok sweet, I do want to keep it, as I like the way it drives but just a bit aggressive on take off, How do I get in contact with Kayne? Thanks Euen are you on Facebook at all I have a couple of question to your motor setup as well? :)
what do you use the car for?
1998 NB MX5 RS TURBO.
Post by REDBEN » Tue Jan 29, 2013 10:33 pm
Mainly just a fun car to Drag/track out of it basically with driving to event here and there.
malcster
Post by malcster » Tue Jan 29, 2013 10:48 pm
REDBEN wrote:
malcster wrote:
REDBEN wrote: Ok sweet, I do want to keep it, as I like the way it drives but just a bit aggressive on take off, How do I get in contact with Kayne? Thanks Euen are you on Facebook at all I have a couple of question to your motor setup as well? :)
ok..mine is a road car and have found since putting back in the torsen its way nicer to drive and not noisey at all...clutch lsds are for racing and drifting and do wear out and how much you adjust them if you can will still be noisey.
Post by REDBEN » Tue Jan 29, 2013 11:02 pm
malcster wrote:
REDBEN wrote:
malcster wrote: what do you use the car for?
I give mine plenty on abuse and to say the least there is more abuse coming once new Motor goes in, ITB's and Turbo :twisted:
Post by tomtikki » Wed Jan 30, 2013 9:40 am
Well after having the roll bar in for about a month with rough paint, no plastic trim or carpet in the car, ive hopefully re-fitted it for the last time.
While the trim looks far from a factory finish, I don't think it looks to bad - a shame i had to cut holes behind the seatbelt to get my fingers through to hold the nuts. -Note: Buy more than the exact amount of nuts and washers, coz when you drop one in the seatbelt tower you have to pull EVERYTHING off again to get it!!
44mm Main hoop, 38mm rear stays.
Post by chris » Wed Jan 30, 2013 11:17 am
Not bad :)
Looks tidy. Needs more low ;)
Post by REDBEN » Wed Jan 30, 2013 11:59 am
tomtikki wrote:Well after having the roll bar in for about a month with rough paint, no plastic trim or carpet in the car, ive hopefully re-fitted it for the last time.
Where abouts did you get this bar from? :lol:
Post by tomtikki » Wed Jan 30, 2013 1:23 pm
How slack of me not to give them a plug as I'm really happy with it!
I took some pictures in to show what I wanted, they made some good suggestions (44mm for the main hoop, just add a diagonal if I want it race spec) and you see the result.
TTT Engineering, on Dominion rd. 09 6310687.
Can't remember the guys name .. But it doesn't matter as it's a small team and only a couple of them do the fab work.
Just between you, me and the web it cost me $600.
Post by punkoutnz » Wed Jan 30, 2013 2:01 pm
I've had a couple of people recommend TTT Engineering to me over the past couple of years so must be a pretty good outfit.
Post by Furai » Wed Jan 30, 2013 2:28 pm
Lowered the front 10mm, I think it looks perfect, handles way better.
Shot from the side for Cordedbowl
Post by Skilfil » Wed Jan 30, 2013 4:25 pm
tomtikki wrote:How slack of me not to give them a plug as I'm really happy with it!
Nice, looks like it'd fit under a hard top too?
Post by Angreal » Wed Jan 30, 2013 4:33 pm
Got home, decided to throw in the towel on my car and get someone else to do the work.
Oh and put in my order for a 6 speed gearbox. Should hopefully arrive in the distantly near future when I'm ready to give it to the workshop with my Japanese mate to put in a crapload of stuff before I go get it certed.
Post by tomtikki » Wed Jan 30, 2013 7:03 pm
Skilfil wrote:Nice, looks like it'd fit under a hard top too?
I hope so, it was done to a height that should clear underneath - I havn't had a chance to check though.
Post by MrGrey » Thu Jan 31, 2013 5:02 pm
Thanks to the helpful information from members here, i ripped in to it and installed my new fusion 8" active sub.
I ended up putting it sideways, low behind the seat.
It sounds great and it not visually noticeable when the seats are in their usual position.
Post by siren676 » Thu Jan 31, 2013 5:30 pm
Nice one. I just got given one of those subs from a friend for working on his car.
Cant think where im going to have to put it as i need the seat all the way back.
Post by MrGrey » Thu Jan 31, 2013 5:33 pm
my seat can still travel right back, there is no restriction on the seat travel in my car.
maybe give it a try, otherwise you could always put it in the boot or your car?
definitely worth installing IMHO
Post by siren676 » Thu Jan 31, 2013 6:10 pm
Isnt the boot a separate compartment? Would have thought no sound would make it through :?
Post by MrGrey » Thu Jan 31, 2013 6:16 pm
from what I have read, boot subs would need a vent of some description into the main cabin to be effective *but* there is anecdotal examples on other forums of some people having success with the sub in the boot on an MX5.
if the drivers seat is out, then the other 3 options I figure are: behind the passenger seat, velcro'ed to sit on the parcel tray (for car thieves to see) or maybe in the footwell on the passenger side.
-=edit=- and I also got around to replacing the missing slidey plate on my ashtray with some alluminium...
sorry about the terrible photo :oops:
Post by warrior » Thu Jan 31, 2013 7:26 pm
I have a sub in the boot...it gets through no worries
Post by chris » Fri Feb 01, 2013 8:44 am
Doesn't matter where the Bass is coming from it WILL be heard.
Sound engineering training paid off ;)
Post by authentic » Fri Feb 01, 2013 10:14 am
Started cleaning/polishing my header. This is gonna take a while.. :?
Post by Angreal » Fri Feb 01, 2013 10:21 am
Just coat it with HPC to save time/effort ;)
Post by authentic » Fri Feb 01, 2013 12:07 pm
I'd still have to take all that black crap off first, which is the time consuming bit. I've hit it with degreaser and WD-40 but its effin stubborn.
Post by Angreal » Fri Feb 01, 2013 12:19 pm
I just gave mine to HPC and they give it a chemical bath first before coating. Should've gone with the Extreme coat though if I was to do it all again
Post by authentic » Fri Feb 01, 2013 12:32 pm
Hmm, what sort of cost would I be looking at? I'm keen on the polished look.
Users browsing this forum: Google [Bot] and 25 guests
