Hi guys...
About to buy a 1 piece NB lower radiator hose to replace the original 2 piece lower hose on my NA. I believe them to be a straight swap? Anyone able to comment?
Lower Radiator hose...
yep,Straight swap,Does mean you have a longer hose to weaken over time,but then no steel pipe in the middle to rot out,50/50 call to say you will gain anything.
Silicone hose's might be a better way to go if you go the one piece,stronger and will not collapse as easy being longer,then again never sold a NB lower pipe thru work before either.
Cheers guys...2 less joins plus weight saving(?) plus precautionary maintenance while steering rack is out was the motivation for the change to the NB hose. Would consider a silicone hose if I could locate one at a reasonable price - any suggestions?????
http://www.corksport.com/samco-miata-ra ... -1.8l.htmlIan wrote:Cheers guys...2 less joins plus weight saving(?) plus precautionary maintenance while steering rack is out was the motivation for the change to the NB hose. Would consider a silicone hose if I could locate one at a reasonable price - any suggestions?????
Users browsing this forum: Google [Bot] and 33 guests
