no spark no.2 and no.3 cyl help needed asap
na6*dori
Post by na6*dori » Fri Sep 14, 2012 10:28 pm
no spark on cyl 2 and 3
, 1 and 4 are fine, coils primary and secondary have acceptable resistance (against w/shop manual)
ecu has nott burnt blocks, nor any burns underneath the board
fuses are all fine.
......any ideas whats causing it?
Post by SLYDIT » Fri Sep 14, 2012 11:41 pm
ignitor module?
by the way DO NOT pull the leads and crank the engine to check for spark...you will F*** the coil packs
oh and also the wiring loom to the coils can get damaged on the rear of the inlet plenum where it is is cable tied to the plenum
na6*dori
Post by na6*dori » Sat Sep 15, 2012 12:46 am
SLYDIT wrote:ignitor module?
cheers, makes sense that one coil is getting signals and one not.
used a tester for the spark, the large gap tends to make a hot spark and fu*ks the coils really good. over time obviously
Post by SLYDIT » Thu Sep 20, 2012 6:53 pm
any luck? what was it in the end?
na6*dori
Post by na6*dori » Thu Sep 20, 2012 7:06 pm
SLYDIT wrote:any luck? what was it in the end?
yep, was bang on the money, odd as to what caused it to fail but guess thats the chance you take with electrical components lol
Post by SLYDIT » Thu Sep 20, 2012 7:25 pm
so it was the ignitor?
na6*dori
Post by na6*dori » Thu Sep 20, 2012 9:14 pm
yes igniter module lol
Post by WideOpenThrottle » Fri Sep 21, 2012 8:11 am
Funny..the workshop pdf says the opposite???
na6*dori
Post by na6*dori » Fri Sep 21, 2012 8:23 pm
the workshop manual is only good for things you know but cant remember lol, diagnosing.....fail haha na im glad its sorted, just ticking over the 200km mark on the new engine
Post by SLYDIT » Sat Sep 22, 2012 3:31 pm
theres been more than a few stories of cars going into workshops with something like a cas fault and when fault finding, the mechs have fried the coils...i wouldnt chance it.
not having the path to earth for the coil voltage causes the voltage in the coilpack to skyrocket. the insulation in the coil internals cannot withstand this extreme voltage and they die. cars which seem to eat coilpacks need to have the engine earths looked at.
na6*dori
Post by na6*dori » Sat Sep 22, 2012 6:14 pm
SLYDIT wrote:theres been more than a few stories of cars going into workshops with something like a cas fault and when fault finding, the mechs have fried the coils...i wouldnt chance it.
put that well i feel. couldnt explain it better
Users browsing this forum: Bing [Bot] and 7 guests
