Post by Mr. Shine » Wed May 30, 2012 2:44 pm
You'll probably want to make sure that the hub-fender measurements are all equal before you get it back on the road! I find 11.5" to be quite driveable without too much scraping...
Post by chris » Wed May 30, 2012 2:48 pm
Once I get home tonight Ill measure it all up :) The first shock removal was a PITA and took about 2 hours that was the front right one.. After that they took about 30 mins each :D
Post by Born_disturbed » Wed May 30, 2012 2:48 pm
Your welcome :P
Post by chris » Wed May 30, 2012 2:49 pm
Haha yes, you pointed out the one damn bolt I forgot :facepalm:
Post by Mr. Shine » Wed May 30, 2012 4:39 pm
Did you drop the upper wishbone longbolt method? Easy as pie :)
Post by chris » Wed May 30, 2012 4:51 pm
yes! haha The first one took ages, but after that I was like "oh, this is easy"
Post by Mr. Shine » Wed May 30, 2012 6:45 pm
Yeah I got tripped up briefly with unbolting the swaybar mounting bolts, but it's amazing how easy it all is after all :)
Post by chris » Wed May 30, 2012 8:54 pm
Yeah after I finally got the first corner done i was like "shit, this will take agess" Then onto the next corner, 30 mins later :D
Post by brownie » Wed May 30, 2012 10:59 pm
Kieran wrote:Does the license plate frame fit?
nope ,set up for us spec plates,shame really .
Post by brownie » Wed May 30, 2012 11:02 pm
Bwarp wrote:Keen for whole car shot with the SSR's on it. They look tasty.
What specs are they?
SSR type C 16x7 +30 offset
Post by Born_disturbed » Thu May 31, 2012 6:41 am
Mr. Shine wrote:You'll probably want to make sure that the hub-fender measurements are all equal before you get it back on the road! I find 11.5" to be quite driveable without too much scraping...
I have 280mm which = 11.02" I scrape if I go too fast over some speed bumps and can get a little guard rub on bumpy roads or heavily cambered corners at high speed
Post by Kieran » Thu May 31, 2012 10:02 am
Already made that mistake once aswell.
Post by Mr. Shine » Thu May 31, 2012 11:09 am
Born_disturbed wrote:I have 280mm which = 11.02" I scrape if I go too fast over some speed bumps and can get a little guard rub on bumpy roads or heavily cambered corners at high speed
Yeah, I'm 11.5" rear and about 11" front, though my cert measurements are something random like 285mm front and 300mm rear, despite ride height not having been changed by me at all...
I find I scrape over the seemingly newer, sharp and squared-off speed bumps, as well as the really short ones you find in some car parks and in rubber form at some shopping mall car parks. I like the rubber ones, sliding rails over them :D
Regular speed bumps are fine, though unfortunately-angled driveway entrances etc. cause scraping too.
Post by Angreal » Thu May 31, 2012 11:17 am
And that sums up why I didn't like my car with its previous lower suspension :shock: At least now it's low but not low enough to hit everything, just the odd thing (but I still go super slow over everything expecting to scrape).
Post by Furai » Thu May 31, 2012 3:23 pm
Got my Handbrake a Gearbox Gaiter from Coxie. Excellent service I must say, only 3 days from asking for a set to having it in the mail. Excellent quality and great price only took 20mins to fit.
Heres pics, I just need a Handbrake handle and Shift knob now to match.
Post by Angreal » Thu May 31, 2012 6:57 pm
Those cover look very similar to the ones I have in my car except my gearbox one has a single stitch down the middle rather than at the corners.
Post by chris » Thu May 31, 2012 9:21 pm
I have just the handbrake one :) Looks great!!
BTW Angreal - I don't think Tina will recognize the car right away if she saw it now.
Post by Angreal » Thu May 31, 2012 11:24 pm
Haha yeah I've been keeping her up to date of the changes 8) ill have to see the car again later this year. My car won't look the same either once my next container arrives from the states.
The only items left on my to do list are getting expensive :-(
Post by Bwarp » Fri Jun 01, 2012 11:44 am
Fuark. Just got a price back for Koni yellows... 354+GST per corner.....without a spring...... farken hell. Lil bit steep I think.
Post by Kieran » Fri Jun 01, 2012 12:35 pm
Thats 1600.70 incl GST...
PASS!!
plus springs and you've got the price of certed coilovers!!!
Post by WideOpenThrottle » Fri Jun 01, 2012 3:04 pm
Bwarp wrote:Fuark. Just got a price back for Koni yellows... 354+GST per corner.....without a spring...... farken hell. Lil bit steep I think.
Try .....http://www.good-win-racing.com/mazda/miata/index.html
I landed mine for half the prive to what i could buy here in NZ!
Post by Angreal » Fri Jun 01, 2012 3:31 pm
I reeaaaaaally want to get some of their ohlins based purely on my friends R1. Can't justify them though
Post by Furai » Fri Jun 01, 2012 4:34 pm
Brand new B6 Bilsteins are about $950ish a set through Autolign...
Post by Born_disturbed » Sat Jun 02, 2012 4:08 pm
Heres mine with the new adjusties, still need to adjust them a bit though
Post by SLYDIT » Sat Jun 02, 2012 9:39 pm
i unbolted my front guards and cleaned the crap out of the lower edge.
The steel is in good nick so thats good news.
Users browsing this forum: Bing [Bot] and 31 guests
