Oils all round
Oils all round
So I've had a read through of the existing oils threads but I feel my queries warrant a fresh thread.
I'm looking to use some of the new Castrol Edge Titanium for an oil change on my NA 1.8.
It has slightly unusual weights, so what should I use out of:
0-40
10-60
5-30
So the 10-60 and 5-30 seem to have quite big and quite small ranges respectively, 0-40 seems the most normal. What do you recon?
I am also looking to do the diff and gearbox oils (I'm replacing the driveshaft so I don't think I have much choice), any recommendations for what to use there?
Does the shifter take the same oil as the main body of the gearbox?
0-40
10-60
5-30
Depends on where you are for engine oil?
Cold climate 0-40
Warm 5-30
Not sure why you would need a 10-60?
Most diff oils will do [80-90] unless you have LSD then get one suitable.
A standard gearbox oil is fine as well...as in everything depends on your purpose & budget!
Regular replacement is the key
Cold climate 0-40
Warm 5-30
I'd say 0W-40 or 5W-30, but personally I'd rather take say Valvoline Synpower's 5W-40 over either of those.
Really, it also depends on what oil weight you're currently using and how much of that, if any, your engine goes through. 0W-40 may end up being slightly too thin on start-up, though it'll be fine once warm. 5W-30 may be fine on start up, but slightly thinner than you may like once warmed up.
Generally, if you find you're burning oil it seems to be advised to try the next highest viscosity oil, so if you're burning a small amount of oil on 5W-30 then you should go up to say a 5W-40 or 10W-40. If you're fine on the oil weight you've been using, try matching it as closely as possible.
I'm in Auckland so warm enough. I've only just purchased the vehicle so I'm not sure what's in it currently. Doesn't seem to burn much/any though. I just like to do a change on purchasing a car because you never know how long it's been.
Everyone has a favourite, so brand wise I'm willing to give this Castrol a shot. Or anything else that has more than 3 backers.
Where can I get Redline stuff from?
Also can someone confirm the shifter oil is the same as the rest of the gearbox?
theres a guy on trademe that sells redline products
the oils i use are a little more pricey but they have never failed me so i continue to splurge on the good stuff but "WideOpenThrottle" is correct regular changes are the key
the difference between the expensive products and the budget products is just time between changes
Im relatively certain the shifter oil is the same
Turret oil is the same as gearbox oil. That redline stuff is good, but bloody expensive. Cheap oil in your gearbox may make for some crap cold shifting, or crap shifting in general.
Personally I run Magnatec 10W-40 cos I'm a tightass on this engine and I'll be building a new one anyway. But have run Castrol 10W-60 in my old pulsar with the engine that I built for that and never had any problems with that oil. Only way to really test though is to send it away for analysis and no one here is up for that!
All of the oils quoted above, while excellent in their own right, are totally unnecessary for an early 90s 1.8 4pot. New engines require this kind of viscosity, a 20 year old engine does not. Now if you were running forced induction, a high powered naturally aspirated engine, or running in extreme temperatures this would be a different story.
The important part of choosing an oil is the rating, the current rating for oil is SM, SN is coming soon, and CI-4 for diesel. The rating determines the amount of additives and detergents in the oil. Newer cars require more of these additives for emissions standards.
These cars that we know and love were not designed with these kinds of oils in mind, hell, they didn't exist then, so spending a lot of money on high-quality modern oil is wasteful, and there are no real benefits.
Also, spend the extra and buy a good quality oil filter, I know too many people who spend upwards of $100 on oil, then skimp out on a 5 dollar filter.
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
Violets are red
Trees are red
Pretty much why I buy the cheapest full synthetic I can find with the viscosity I need (5W-40), which is usually Valvoline Synpower for ~$50 on specialm4vr1k wrote:These cars that we know and love were not designed with these kinds of oils in mind, hell, they didn't exist then, so spending a lot of money on high-quality modern oil is wasteful, and there are no real benefits.
A thinner oil is good on startup as it gets around the engine quicker.
I did use Mobil 1 there for a while...but that gave me crap oil presure.
I changed to a semi synthetic Penzzoil product and have never had any issues.
The oil stays really clean, and I have good pressure even after a few hot laps and everything is still hot.
And the answer to your other question is yes you can use the same oil for the shifter that is used for the gearbox.
Personally I use engine oil as its a little thinner but each to their own.
Of course, this is only true of the cold viscosity rating of the oil. I find 5W to be a good cold viscosity to avoid noisy hydraulic lash adjusters on start-up, but if you have solid lifters (NB engines?) or don't have noisy HLAs, then 10W should be more than suitable for cold starts.Growler wrote:A thinner oil is good on startup as it gets around the engine quicker.
noisy
I know this is an old thread but rather than start a new one though I would tale onto this one.
I have read most threads I have serviced my 90 mx5 1600 with Magnatec as I always use this! however after roughly 500klms, have noticed today the lifters seemed noisy after the innitial start up?
once warm it really annoyed me, what would be the best remedy for this maybe oil wise or other? thanks.
I cant see why eveyone uses MT90 REDLINE in there gearbox? Read the info about it on FLYIN MIATA, they say it should only be used in race cars as it does not work well until hot. For day to day driving MT90 should not be used. Just because it costs the most does not always make it the best product for our cars.
Re: noisy
no amount of oil changes will get rid of hla tickpommy wrote:I know this is an old thread but rather than start a new one though I would tale onto this one.
here have a read
http://www.miata.net/garage/hla/cleaning.html
It works well in street driven 6speeds I hear all the 6speed drivers swear by it so I will post what I think when i finally get around to it Ive got it sitting at home gathering dust hahawarrior wrote:I cant see why eveyone uses MT90 REDLINE in there gearbox? Read the info about it on FLYIN MIATA, they say it should only be used in race cars as it does not work well until hot. For day to day driving MT90 should not be used. Just because it costs the most does not always make it the best product for our cars.
Re: noisy
Man, fixing it sounds like such a mission. The NB cams and lifters also sounds like a mission to install. I might give the NB cam/lifter swap a go in the distant future maybe but I think I'd need a plan B (someone comes and finished the job in my garage when I get 80% of the way) before I attempt itsprsta wrote:no amount of oil changes will get rid of hla tickpommy wrote:I know this is an old thread but rather than start a new one though I would tale onto this one.
here have a read
Just wanted to backup what was posted above by Growler.
When my new clutch was installed the mechanic recommended using engine oil as he was told at a conference that most gearboxes work well with it. Improved shifting etc...That many "gearbox" oils were too slippery and the synchros can't work properly.
I was a bit nervous but have experieced the exact same thing with my race bikes....(you don't want to miss a shift in a national MX race on the face of some hairy ass jump!)
Turns out he was right. Shifts beautifully even when cold and shifting to second cold had always been a bit of a problem.
