Need to find a MX5 mechanic ...
Blubee
Post by Blubee » Fri Mar 16, 2012 3:12 pm
Hey
Blubee is a 1990 MX5 (really????) and shes screaming her nut off at me! Literally! :cry:
I was told by a friend that either the belts need tightening OR the air con needs to come out as there is a ?broken? bearing and get a shorter belt.
Been a savy kindof person, I've googled that awful noise and have read how to do it and seen the pix - but as wonderful as that sounds, I'm not really in the mood to munt my baby - thus I rather have it fixed by someone who knows what the are doing - without the big ripoff!
So - if anyone knows someone who knows what the heck they are doing please let me know ... referrals are good things! And if anyone knows what the estimated cost of repair is - please let me know!
Had Bluee for around 4 years and this is the 1st repair thing that I've had to do ...
Thanks!
... live the life you love so you can love the life you live ...
Post by Born_disturbed » Fri Mar 16, 2012 3:42 pm
Location?
mazline
Post by mazline » Fri Mar 16, 2012 4:49 pm
Location,location,location :)
Brainflex
Post by Brainflex » Fri Mar 16, 2012 7:11 pm
location, location, location, location, location? :twisted:
m4vr1k
Post by m4vr1k » Sat Mar 17, 2012 9:17 am
Location?
Location location location location location location.
location.
location location location location location location location location location location location.
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
mazline
Post by mazline » Sat Mar 17, 2012 12:28 pm
Can you see a theme here?????.
We all want to help but gotta know your ,LOCATION :roll:
Blubee
.... oops....
Post by Blubee » Sat Mar 17, 2012 1:05 pm
Okay - sorry ppl!
And yes ... if you hadn't already guessed ... I am blond!
Anyhow ... Location = North Shore Auckland!
Thanks!
Post by harlansmart » Sat Mar 17, 2012 3:16 pm
What's actually wrong, I'm also on the Shore and equipped to do very basic things.
Post by punkoutnz » Sat Mar 17, 2012 3:51 pm
Sounds like it just needs a belt replacement to me. When my alternator belt got a bit loose it howled something shocking.
Blubee
Post by Blubee » Sat Mar 17, 2012 4:26 pm
Well, when I start her up something is making a hell of a screaming noise. When I accelerate it gets a bit more high pitched. I'll turn off the engine and restart a couple of times n that stops it... Well it did the first few times. I had the radiator fixed about 6 weeks ago. Will record n post.
Blubee
Post by Blubee » Sat Mar 17, 2012 4:55 pm
:shock:
As attached...wma format
Post by sprsta » Sat Mar 17, 2012 5:16 pm
do you have air conditioning and/or power steering
im in murrays bay and can tighten/replace your belt if you like
give us a call or txt 0211220097
Cole
Post by Mr. Shine » Sat Mar 17, 2012 6:32 pm
Replace the alternator/accessory belts. They're cheap enough replacements and if you're doing one you may as well do them both.
Post by Born_disturbed » Sun Mar 18, 2012 12:43 am
Tighten or replace them, im also in Murrays bay if you want a hand. Just down the road from Cole heh
David - 021 022 14187
Post by Kieran » Mon Mar 19, 2012 10:49 am
Probably just need to be tightened
is there a date written on the valve cover or a sticker in the enginebay that says when the belt was last changed?
Post by Mr. Shine » Mon Mar 19, 2012 8:09 pm
Kieran wrote:Probably just need to be tightened
Don't think I've ever seen this done for accessory and alternator belts, though certainly the timing belt.
Post by Kieran » Tue Mar 20, 2012 9:41 am
9 times out of 10 the problem is the timing belt
Post by Mad Kiwi » Tue Mar 20, 2012 11:43 am
I doubt the timing belt will scream, it has teeth on it and can't slip.....
If you want a commercial mechanic, the guys behind me in Barrys Point Rd look after our two.
AutoPal, ask for Andrew.
Mark.
Post by Mr. Shine » Tue Mar 20, 2012 10:54 pm
Kieran wrote:9 times out of 10 the problem is the timing belt
I think the issue is more the accessory/alternator belts slipping, usually because of the belt surface getting glazed, or loosening up. My belts squeal a bit in cold or wet weather, but are fine otherwise.
That suggests to me they need replacing rather than tightening, though.
Post by SLYDIT » Wed Mar 21, 2012 10:59 pm
i always roughen up the pulleys with 80 grit sand paper. its better to make the pulleys have more grip on the belt rather than over tightening the belt as it over loads the bearings
Blubee
Post by Blubee » Fri Mar 23, 2012 1:38 pm
Okay, I'm back - sorry for the departure from my own question forum..Had the belts replaced. apparently there is "play" I'm the passenger side fan ie it moves a bit. However a new fan is gonna cost around $600.... The other school of thought ie wkmates opinion is that it could be a bearing in the air con...
Post by Kieran » Fri Mar 23, 2012 2:20 pm
If its the A/C get rid of it cost of fix $0
Post by SLYDIT » Fri Mar 23, 2012 4:57 pm
there are two fans. one is the cooling fan. the other comes on when the air con is on. i ripped out my air con..(ITS A FREAKIN CONVRTIBLE PUT THE TOP DOWN) and wired my fans in paralell.
Post by WideOpenThrottle » Fri Mar 23, 2012 6:11 pm
Take the air-con belt off & try it-it wont hurt anything but will help to eliminate or confirm if its the air-con.
Also you could disconect the fan electrical plugs to check both fans!
Only do for a short while & keep an eye on your temp gauge!
Post by Mad Kiwi » Sat Mar 24, 2012 12:19 pm
I would discourage removing aircon unless it is a race orientated car. Of our two mx5's the un aircon one is bloody hot and uncomfortable driving around in.
With such a small cabin and often a black roof, it can get pretty damn hot, not to mention being baked/scorched under our ozone hole sun....
If you pull the plug on each fan independantly it shouldn' over heat and you can easily tell if that is the cause...
Users browsing this forum: Google [Bot] and 25 guests
