Sea foam?
Sea foam?
Post by warrior » Thu Dec 15, 2011 7:14 pm
Any one out there done this to there car? Have looked all over the net and seems to be fairly good. Any ideas?
Post by WideOpenThrottle » Thu Dec 15, 2011 7:43 pm
Just try a few drops of baby oil [works wonders so i am told-never tried it]!
Like most additives how does one quantify their effectiveness-quality oil & regular maintenance should be the main prority! :D
Sea foam?
Post by biff » Fri Dec 16, 2011 10:42 am
What are you two talking about, simply 2 emails, is there a thread, some
initial info on the discussion?
Got me, nothing but the two entries on a page on the site, got me
Post by warrior » Fri Dec 16, 2011 11:29 am
never heard the one about baby oil? I agree about the oil change etc but this stuff is ment to clean all the carbon build up in the fuel system, and engine. So its not really an aditive more of a cleaner.....oh and cleans the inlet manifold as well.
Sea foam?
Post by jif » Fri Dec 16, 2011 11:35 am
SeaFoam is used to de-gunk engines, so if its pinging more than it should that'd be the time to consider doing this.
I used to just spray water into the engine (with a spray bottle, not a hose !!) after the airfilter and with the revs up as this has the same effect.  And then change the oil afterwards.
Prob about as harmful as driving on a foggy Waikato morning ;)
Sea foam?
Post by biff » Fri Dec 16, 2011 5:04 pm
Oh, now I understand, sorry, hadn’t heard of SeaFoam, couldn't understand
the thread................ duh
m4vr1k
Post by m4vr1k » Fri Dec 16, 2011 5:40 pm
I use an STP oil flush every few oil changes, works a charm, especially the first time, all kinds of gunk ends up in the waste oil.
Also, I find that if I take the car for a quick thrash after adding the flush, to really get the oil pressure up, it seems to clean a bit more thoroughly.
Although, I must add, that it says specifically not to do that on the bottle....
Also, Pro-Ma MBL8 is your friend, every oil change.
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
Post by Skilfil » Fri Dec 16, 2011 6:09 pm
So everyone else gets ticking on their 1.6? Did a recent oil change with some 10w40 and it still ticks loudly, may try the pro mlb stuff heard really good things about it.
RMS
Post by RMS » Fri Dec 16, 2011 9:56 pm
Skilfil wrote:So everyone else gets ticking on their 1.6?
I did on my 1.6 although it's been a lot better since I pulled all of the lifters out and cleaned them. Not a fun job though and one of them is still ticking.
Post by WideOpenThrottle » Sat Dec 17, 2011 8:27 am
Skilfil wrote:So everyone else gets ticking on their 1.6? Did a recent oil change with some 10w40 and it still ticks loudly, may try the pro mlb stuff heard really good things about it.
Try castrol magnatec-cleared up mine & have read it was good for others with bad tickers! :D
Post by Mr. Shine » Sat Dec 17, 2011 10:52 am
I've used ATF as a flushing oil in the past. It's basically just a thinner oil to get into nooks and crannies to remove crud.
Post by Skilfil » Sat Dec 17, 2011 3:57 pm
WideOpenThrottle wrote: Try castrol magnatec-cleared up mine & have read it was good for others with bad tickers! :D
Yeah I used that, hasn't done much for mine. I'll try the pro stuff, if that doesn't work then I'll put a weekend aside and do the annoying bit.
thebears
Post by thebears » Sun Dec 18, 2011 9:30 am
won't it rust the motor - Seas Foam?
Post by punkoutnz » Sun Dec 18, 2011 10:33 am
Sea foam is the brand name, it's not actually sea foam, haha. I've used similar stuff in a few different engines over the years, found it to be pretty good. Especially in engines with the rocker cover vents plumbed back into the engine (for emissions). This eventually builds up on the throttle butterfly and around the intake valves.
Post by Mr. Shine » Sun Dec 18, 2011 1:24 pm
I believe Subaru's Upper Engine Cleaner is fairly similar.
dynofiend
Post by dynofiend » Mon Dec 19, 2011 6:30 pm
Id avoid this kind of stuff if I were you. It will do nothing to remove any coked on deposits or glazing in the combustion chambers, and will have a limited effect, if any at all on removing built up oil emulsion in the induction tract.
Better bet is to dismantle the induction as far as you feel comfortable, and use a damp rag to clean it.
Carbon deposits in the engine will only be removed by rebuilding the engine, and do very little to hamper engine performance in our road cars anyway.
m1atamad
Post by m1atamad » Fri Dec 30, 2011 12:18 pm
Don't know about sea foam but we used to use mineral hydraulic oil poured gently into the carb (yes I know .... I'm OLD) and it cleans up the combustion chamber and piston crown bloody well.
As for lifter ticking........try running a good grade of diesel oil for a couple of hundred Kms.....they have more detergents in them, I've done it with a few cars when I've first got them to clean everything up. My old NZ had chronic ticking (not just when cold) when I got it, oil change to diesel at Taupo, drove to Palmy North and changed oil and filter never had any problems from then. Owned for 6 years with regular oil and filter changes.
Just my 2 cents worth :)
