Auto & Manual engines
Post by WideOpenThrottle » Mon Nov 14, 2011 9:06 pm
Hi
Does anybody know for sure if the NA 1600 Auto engines as found in NZ are the lower HP ones with a milder cam?
According to some US sites they are!-[ between 1989-1993].
Most wreckers/dealers i have talked to in NZ have never heard of this difference.
As i am now needing a replacement engine rather than a re-build & i sure would like to have some clarification on this as it may have some bearing on being turbo'd & possible shortcomings?
Post by punkoutnz » Mon Nov 14, 2011 9:15 pm
Yes I believe they are. However my car was originally an automatic and I think if anything, the auto engine will be even better with a turbo bolted onto it. Mine certainly has a huge whack of down low torque! Even off boost...
Post by sprsta » Tue Nov 15, 2011 7:25 am
auto engines have a variable TPS also, which is handy if you want to use tps based boost control
Post by WideOpenThrottle » Tue Nov 15, 2011 10:45 am
punkoutnz wrote:Yes I believe they are. However my car was originally an automatic and I think if anything, the auto engine will be even better with a turbo bolted onto it. Mine certainly has a huge whack of down low torque! Even off boost...
So do you think that they lose power/torque at high rpm earlier than the manual engine or much the same?
Post by WideOpenThrottle » Tue Nov 15, 2011 10:47 am
sprsta wrote:auto engines have a variable TPS also, which is handy if you want to use tps based boost control
So would that run off the ECU or be vacuum/boost based or sensed directly off the TPS?
Post by sprsta » Tue Nov 15, 2011 11:21 am
WideOpenThrottle wrote: So would that run off the ECU or be vacuum/boost based or sensed directly off the TPS?
You would need an ecu capable of controlling boost
RMS
Post by RMS » Tue Nov 15, 2011 12:23 pm
CR is supposed to be 9.0:1 on the auto as opposed to 9.4:1 on the manual.
I would think that the lower CR would allow more boost/ignition advance that would more than offset the cams anyway?
Post by SLYDIT » Tue Nov 15, 2011 7:42 pm
the auto engine will alow "more boost" but it won't make any more power at that boost because it is a less efficient engine, and will only flow the same volume of air at the higher boost level as the high CR engine at a lower boost level.
the lower compression will only give you a wider window to tune in before knock sets in. And with todays modern ECU's theres no point.
even if going turbo , get a normal engine and enjoy the benefits of better economy and throttle response.
as ive said before the #1 limit to how much HP you can make with a 1600 is the strength of the conrods. and both manual and auto share the rods anyway..
you can bolt on a BMW 318 tps sensor in place of the mx5 one if you need a variable TPS for an after market ECU.
Post by WideOpenThrottle » Tue Nov 15, 2011 8:23 pm
Thanks slydit on your response... a few good reasons to stick with a manual one.
Incidentally is there any engine markings to indicate a true manual one?
mazline
Post by mazline » Fri Dec 02, 2011 4:41 pm
Cam numbers and number on top of the throttle body,Thats about it.
zippy2
Post by zippy2 » Fri Dec 02, 2011 6:12 pm
is this the same for the 1.8s where the auto motor is different ?
Post by Euen » Sat Dec 03, 2011 9:47 pm
No, the 1.8s were the same for auto and manual.
Users browsing this forum: No registered users and 77 guests
