NA exhaust
NA exhaust
Post by warrior » Wed Nov 09, 2011 3:35 pm
Before I put in my supercharger I am going to do the exhaust on my 1.6 NA. I have a stainless steel rear muffler coming but need some headers and a conecting pipe. So I have a couple of questions.
1. Any one know where I can get some good headers? REDLINE PERFORMANCE have some stainless ones for sale on trade me for $299. Anyone used these? They look great but are they any good?
2. I will be removing the CAT but should I stick with a pre silenser or just use a straight through pipe?
3. Where is a GOOD exhaust shop that does not charge an arm an and leg for work?
Any help you can give would be great
m4vr1k
Post by m4vr1k » Wed Nov 09, 2011 5:57 pm
1. Don't know
2. Yes, replace the cat with a Coby or similar. Replacing with a bit of pipe can make the exhaust have a horrid cackle in it, especially on overrun
3. What part of Auckland are you in? I know plenty of good exhaust shops in Rodney, but other than that, I have had two exhausts done by Pitstop in Wairau road, and was very happy.
Also, for the best flow, make sure you use a shop with a mandrel bender, or purchase exhaust donuts. Keeps the diameter of the pipe consistent through the whole system.
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
Post by sprsta » Wed Nov 09, 2011 6:03 pm
born_disturbed has a set of 1600 jasma's
try pm'ing him
takapuna mufflers or pitstop grey lynn both do good work
Post by warrior » Wed Nov 09, 2011 6:18 pm
Thanks for that, I am in Manurewa and will travel to a good shop if I have to. Will be going with mandrel bends 100%. Will only need a mid pipe after I get the headers and muffler so not hard to make im sure.
NA exhaust
Post by jif » Wed Nov 09, 2011 8:07 pm
1/ headers - make sure whatever you get works with a hotside supercharger (assuming yours is not a coldside kit)
2/ ask the muffler shop (see #3), they prob have a very good idea of results having done it before.
3/ I've used Al's mufflers (Wairau park) several times and am v.happy - but any other place that advertises in the back of hot rod magazines would also be pretty good I'd think.
The final exhaust on mine (after several changes!) was 2.5" , with a resonator and S-bend (ie non-chambered) rear can. It was a bit quiet with the turbo, but would prob perk up a bit with a SC.  :]
HTH-
-j
Post by SLYDIT » Thu Nov 10, 2011 7:13 am
if your thinking about headers/extractors then budget on a new oxygen sensor too.
most extractors place the O2 sensor too far away from the engine and they dont get hot enough..you have to fit a heated O2 sensor.
Post by sprsta » Thu Nov 10, 2011 7:30 am
Or if your going with a super charger you should be going with a wbo2 anyway, they're pretty cheap now days
Post by warrior » Thu Nov 10, 2011 9:54 am
sorry but what is that?
Post by punkoutnz » Thu Nov 10, 2011 10:07 am
Short for wide band O2 sensor.
Post by warrior » Thu Nov 10, 2011 10:20 am
right.......thanks
Post by SLYDIT » Thu Nov 10, 2011 8:24 pm
heres what your after...probably cheaper than a genuine o2 sensor any way...a must have for DIY tuning...
http://www.diyautotune.com/catalog/inno ... -p-41.html
Post by sprsta » Thu Nov 10, 2011 8:33 pm
I got mine from euro performance
http://www.europerformance.co.nz/
i think nz performance does them also
i paid about $300 or so with a G3 gauge about a year ago
Users browsing this forum: Google Adsense [Bot] and 33 guests
