Cert for turbo
RMS
Cert for turbo
Post by RMS » Tue May 31, 2011 5:03 pm
I am just finishing off a project to turbocharge my '89 eunos roadster.
Can anyone recommend a good certifier in the auckland area? I know there is a list on the lvvta web page but I would appreciate recommendations.
It will also need to be certed for coil over suspension that I have added.
Having read the technical documents on the lvvta webpage I think that the car is well prepared for the cert with the exception of a driveshaft hoop. Can anyone tell me if the PPF is likely to cause problems with fitting a hoop?
Also, on the topic of certs, it's interesting to note that a change of turbo or even wastegate requires a cert... I reckon there's a lot of cars out there with upgraded turbo systems and no cert though.
m4vr1k
Post by m4vr1k » Tue May 31, 2011 6:04 pm
If you are on the shore, I can recommend Neil Fraser at Fraser Cars, he is in the Birkenhead area
Roses are red
Violets are red
Trees are red
Oh fuck, my garden's on fire
Post by sprsta » Wed Jun 01, 2011 7:17 am
i just used a length of 50X5mm strap and bolt it arround the drive shaft to the top and bottom of the PPF about 100mm from the front universal
as for cert
i used john brett he is good and will come to you if you can source a hoist
0800lowvolume
RMS
Post by RMS » Wed Jun 01, 2011 12:33 pm
Thanks,
sprsta: Do you mean you bent a piece of 50x5mm bar into a U shape and bolted that to the PPF or am I misunderstanding you?
That certainly sounds like an easy way to do it.
Post by sprsta » Wed Jun 01, 2011 2:00 pm
like this
RMS
Post by RMS » Thu Jun 02, 2011 8:17 am
Thanks, I was understanding you correctly then.
actually looks a lot simpler than the hoops that bolt to the chassis.
Did you have to remove the PPF to drill the holes?
Post by sprsta » Thu Jun 02, 2011 4:42 pm
Nah, i think i had the drive shaft out though
:D :D and the car was on a hoist :D :D
Post by SLYDIT » Thu Jun 02, 2011 8:39 pm
what's with the driveshaft hoops? when did this become a must have?
my car is certed for turbo without a hoop.....
RMS
Post by RMS » Mon Jun 13, 2011 10:05 am
Got it sorted, I had mine go around the outside of the PPF but it's basically the same :)
Was a real pain drilling the top of the PPF though, luckily the previous owner of my shed was a mechanic and there's a ramp outside that provides access to the underside of the car and also had to take the drive shaft out.
SLYDIT: Reading the pdf's on lvvta.org.nz it seems to have been required since at least Sept 2002.
Anthug
Post by Anthug » Mon Jun 13, 2011 10:38 am
Certifier didn't mention hoop requirement when okaying my turbo install.
Post by Euen » Mon Jun 13, 2011 8:09 pm
I had to have one when I got the TG certed. I just used a length of stainless wire rope across the tunnel.
RMS
Post by RMS » Tue Jun 21, 2011 3:40 pm
ALLLLLLL good :)
RMS
Post by RMS » Tue Jun 28, 2011 6:57 pm
<500km and my cheap trademe manifold has cracked, didn't think I'd have to build my steam pipe manifold _quite_ this soon.
Post by sprsta » Tue Jun 28, 2011 8:19 pm
Tisk Tisk Tisk
The old do it twice do it right story eh?
Those stainless things arent even worth the postage
RMS
Post by RMS » Wed Jun 29, 2011 1:47 pm
well, it was the manifold impulse buy that got me started down this track so I can't feel too bad about it :)
Still, thought it might give me a month or two at least, I built a bracket to support the weight of the turbo too.
RMS
Post by RMS » Tue Jul 05, 2011 4:13 pm
Built a new steampipe manifold over the weekend using autobend flanges... she's not pretty but it got me home :)
The 'ebay' manifold doesn't just have a crack in it, it's actually had a piece fall right out. hate to think that that would have done if it went through the turbine.
RMS
Post by RMS » Fri Jul 08, 2011 9:08 am
been driving the car for the last few days and all seems good. Had to remove the gasket between the manifold and turbo as it disintegrated but otherwise all good.
Weather permitting I'll be at Pukekohe on the 16th to see how she handles some real heat.
Post by Mad Kiwi » Thu Nov 03, 2011 2:09 pm
On the subject of certifiers, how much does it usually cost to certify say, new coilover suspension and what is usually involved?
Mark
Post by Euen » Thu Nov 03, 2011 2:47 pm
Usually about $400 give or take. If you are on the Shore, have a talk to Neil Fraser. His contact details are on the LVVTA website.
He will normally give the car an inspection and test drive and let you know if you need to do anything.
If you can, it is usually best to get several mods certed at the same time, otherwise it can get expensive.
Post by sprsta » Thu Nov 03, 2011 4:58 pm
i used John Brett ( 0800LOWVOL) he costs about $500 inc GST and is mobile so if you find him a hoist he can do it
it is best to do as much modification as you can to get certified at once
as it doesnt matter if you are only certing one or 50 things
Post by Mad Kiwi » Thu Nov 03, 2011 6:06 pm
Thanks guys.
Post by SLYDIT » Thu Nov 03, 2011 7:22 pm
be aware that you need to have your car set up at the height you want the car to stay in...
they measure the ride height at certification time and you can only deviate from that by 5%...
so put in your coilovers get them all settled in and get a weel alignment THEN get the cert done...
OH and you cannot get a new wof until you have the actual steel plate attatched to the car.I got caught out as my wof ran out AFTER it had its cert done....so i had to wait for the pen pushers to process my cert and send the plate...not fun.
Post by Mad Kiwi » Thu Nov 03, 2011 10:43 pm
Aha, great advice...personal experience. Thank you, i didn't know they cert'ed the height as well...
I guess my old RX3 with cut springs need no longer apply :)
Dunno, felt safe at the time :shock:
Users browsing this forum: No registered users and 62 guests
