Anyone had an inlet valve clearance sudenly drop to ZERO
KSCRIM
Post by KSCRIM » Sun Jul 03, 2011 5:43 pm
I have one inlet valve on #1 down to 0 clearance, ALL others are normal, exhaust also normal. I have a bad cold misfire which reduces to minor when warm. Nothing else is faulty, been through everything. Just #1 compression down to 150.
This suddenly started a few weeks ago, engine was fine before then.
It is a JDM 98NB 1600 with solid lifters, the shims are all similar thicknesses.
Have I dodged dropping a valve? and the stem has stretched??
I've posted in the Miata forum also.
KSCRIM
Post by KSCRIM » Mon Jul 04, 2011 2:42 pm
The head is at the doctors to have a new valve fitted and re-shimmed. He will replace all 16 guide seals and fit new cam seals also.
Pix on the Miata.net forum http://forum.miata.net/vb/showthread.php?t=426120
KSCRIM
Post by KSCRIM » Fri Jul 08, 2011 8:55 pm
The head is back, 1 new valve, 16 new stem seals, 2 new cam seals, clean and set up (the shim was still the right thickness). Pix of the valve face in the Miata thread.
KSCRIM
Post by KSCRIM » Sat Jul 09, 2011 5:28 pm
We are up and running again, no problems starting once the fuel pressure was up. Smooth and quiet, wonderful!!.
