Now its cluth time
Now its cluth time
Post by WideOpenThrottle » Wed Mar 09, 2011 10:49 am
Got my WOF this morning & no need to get a cert for my Turbo :D
The down side is noticeable slippage from the clutch so now i need to lookout for a set-up that will handle up to 10psi boost just to be on the safe side.
I would imagine the 1800 clutch might not be enough?
It needs to be mainly for road use and occaisional track days.
Penny for your thoughts
Post by sprsta » Wed Mar 09, 2011 2:11 pm
get a 1800 fly wheel and have it lightened to about the 1600 weight then use a HD clutch on that itll hold no problems
Post by Kieran » Wed Mar 09, 2011 3:59 pm
If you dont mind spending a bit of money you could always get a clutch kit from somewhere
I know Flyin miata in the states do a kit for Usa$600 which includes Level 1 clutch rated for 318 lb/ft of torque, a lightweight flywheel, clutch switch override, pilot and release bearings or the slightly bigger kit which is Usa$50 more
Check it out
http://www.flyinmiata.com/index.php?dep ... r=08-36000
Post by brownie » Wed Mar 09, 2011 4:41 pm
BNT automotive have got good quality clutch kits,Check out your local branch
Post by WideOpenThrottle » Wed Mar 09, 2011 7:07 pm
sprsta wrote:get a 1800 fly wheel and have it lightened to about the 1600 weight then use a HD clutch on that itll hold no problems
Thats an interesting idea! sprsta. How much does it cost for lightening & who does it?
Last edited by WideOpenThrottle on Wed Mar 09, 2011 7:10 pm, edited 1 time in total.
Post by WideOpenThrottle » Wed Mar 09, 2011 7:09 pm
Kieran wrote:If you dont mind spending a bit of money you could always get a clutch kit from somewhere
Check it out
Thanks Kieran-but i need something fairly pronto & after being lumbered with about 20% import duty on my Voodoo Box & gauges i will give it a miss!
Post by WideOpenThrottle » Wed Mar 09, 2011 7:11 pm
brownie wrote:BNT automotive have got good quality clutch kits,Check out your local branch
Thanks brownie will ring them 2moro & sus -out
Now its cluth time
Post by jif » Wed Mar 09, 2011 10:42 pm
On 9 March 2011 10:49, WideOpenThrottle <horsepower@mx5forum.co.nz (horsepower@mx5forum.co.nz)> wrote:
The 1800 clutch (mine, with 100k on it) held 10psi/180hp mostly ok ... only some slight slippage on colder nights at 4-5000rpm.
In hindsight it'd have been better and cheaper to stick with it and a slightly higher pressure plate. The ACT that replaced it pretty expensive and felt like it had close to zero freeplay in it for the first month or so !!! :P
Post by WideOpenThrottle » Thu Mar 10, 2011 8:46 am
Well i hope to go with an an 1800 set up but will have to find a fly-wheel first!
Post by Euen » Thu Mar 10, 2011 9:36 am
You could also talk to the guys at Exedy (Wairau Rd, North Shore). They do a few options for the MX5 and the price isn't too bad.
Be careful though. The HD Exedy stuff that comes out of Australia is not worth having. The Jap clutches are good though.
Post by WideOpenThrottle » Thu Mar 10, 2011 10:49 am
Euen wrote:You could also talk to the guys at Exedy (Wairau Rd, North Shore). They do a few options for the MX5 and the price isn't too bad.
Hi Euen....only got Aussie ones so will give them a miss.
Thanks all the same.
cappo1
Post by cappo1 » Sat Mar 12, 2011 9:02 am
Hi G, Great to see you are on the road after all your hard work.
Although my 5 only gets out for a few hundred k's in between WOF as I wait for some time to finish my basic tune the clutch has never slipped and it runs a constant 15psi, the fly wheel came from Jif via Poison thanks!, I can't remember if the clutch came with it or if a new clutch/pressure plate was bought.
Prior to getting this clutch I was told a Mazda 323 1600 Turbo set up could be fitted??? might be worth a few phone calls, I may have a 323 fly wheel in the garage some where. cheers
Post by WideOpenThrottle » Sat Mar 12, 2011 10:24 am
cappo1 wrote:Hi G, Great to see you are on the road after all your hard work.
Hi cappo
Funny you should mention it but i still have the 323 clutch & flywheel & i never ever thought that it may fit!
Maybe its worth investigating?
WOT
Post by WideOpenThrottle » Sat Mar 12, 2011 11:58 am
Actually now that i remember, the clutch was slipping on the old car so i dont think i will try the 323 set-up.
Post by SLYDIT » Mon Mar 14, 2011 9:42 pm
i'm running a heavy duty 1800 clutch in mine. it is an "xtreme" clutch from aus. seems ok but maybe if you want to be 100% sure get the clutch from FM i think thats called an extreme too but its bullet proof. most HD clutches are a hit and miss affair that FM clutch is gauranteed.
Post by WideOpenThrottle » Tue Mar 15, 2011 8:08 am
SLYDIT wrote:i'm running a heavy duty 1800 clutch in mine. it is an "xtreme" clutch from aus. seems ok but maybe if you want to be 100% sure get the clutch from FM i think thats called an extreme too but its bullet proof. most HD clutches are a hit and miss affair that FM clutch is gauranteed.
Cheers slydit i think i will be getting an extreme BNT one soon :D
Post by WideOpenThrottle » Thu Mar 17, 2011 2:47 pm
Got my clutch out so hopefully will be putting it all back 2moro with a bigger flywheel & BNT sprung button disc kit but i seem to have this little pin now & i have no idea where it came from!
Anybody seen one before?
Cheers!
WOT
Post by Euen » Thu Mar 17, 2011 3:01 pm
Did it come out with the old clutch or was it in the box with the new one?
Post by Keith Jones » Thu Mar 17, 2011 3:10 pm
Looks like one of the rollers from the spigot bearing.
Post by WideOpenThrottle » Thu Mar 17, 2011 3:33 pm
Thanks Keith
Funny how it goes it actually came out of the handle end of my torque wrench! [embarissing].
WOT
Post by sprsta » Thu Mar 17, 2011 4:50 pm
i was just about to say it looks like part of a torque wrench :lol: :lol:
be sure to get BNT to machine your new flywheel
Post by WideOpenThrottle » Fri Mar 18, 2011 11:22 am
Would you believe it Bnt have no xtreme sprung button clutches in the country after telling me it would be here this morning & offered me a pink Exedy equivalent! :evil:
Could be over a week to get an extreme one from Aus.
Waiting to see what they come up with otherwise i will have to invent plan "B".
"Bugger"
Post by sprsta » Fri Mar 18, 2011 4:13 pm
an exedy sports tuff will hold
or get autoclutch to build one for you did your flywheel come with a clutch attached so they can rebuild that with extra clamp pressure
Post by WideOpenThrottle » Wed Mar 23, 2011 8:30 am
Got in my new HD Clutch kit,machined flywheel,new spigot & release bearing all after a bit of grunting & cursing.
I thought it might be all wrong as i couldn't mate the gearbox to the engine & had three goes at it. [must invest in a hoist, damm this laying under cars}.
I measured the clutch kit for depth & diam. that all seemed fine,re-aligned the clutch plate for centre untill finally on my last attempt it went on a breeze!! :D
This is the first time i have used a centering tool & i am thinking that even with that all the new bits need more accuracy even when using the tool.
Took it for a test drive & all seems great apart from almost no travel before uptake but i am happy with that as it means quicker gear change.
Looks like i will make it to Driver traing at Taupo this weekend so see you there if anybody is going [shame about the weather as it might be wet.Na!!]
Post by Kieran » Wed Mar 23, 2011 11:44 am
If its wet that just means more fun less clutch kicking
