WANTED NB UPPER SHOCK MOUNTS (SET)
Post by warrior » Thu Dec 02, 2010 8:31 pm
I am after a set of NB upper sock mounts...I have heard they will give my NA car a bit more travel in the suspension. Anyone got a set lying around they would like to sell?
aidwano
Post by aidwano » Sat Dec 18, 2010 11:03 am
I bought 4x of these components from mazda this year:
28-340A : Upper Perch
28-776B : Lower Bush
from an NB. Cost about $120.
This could be an option for you.
I cut the each bush in half, then took about 2mm more off one side. I put one half on top, one half on bottom of the perch. Then a large washer and a nut.
It doesn't have as much flex as a standard perch, but it seems to do the trick and I havent had any problems. It will lower your car about 7-10mm without losing travel.
