Oil feed for turbo
Oil feed for turbo
Post by WideOpenThrottle » Mon May 17, 2010 2:10 pm
Because my NA6C now has a turbo just how do i get oil feed for it?
Also can you purchase a sump oil return fitting anywhere?
Post by Keith Jones » Mon May 17, 2010 5:12 pm
There is a plug into an oil gallery at the back of the block by the dipstick.
I made up a fitting to go in here as it's close to the turbo.
I've got a few fittings that might do for the sump return. I'll check tonight.
Is the engine in the car yet as it's a fiddly job drilling and tapping the sump if it is?
Post by sprsta » Mon May 17, 2010 6:35 pm
http://www.miataturbo.net/showthread.ph ... post573401
see post #29
i got all of my fittings from ENZED
http://www.fpp.co.nz/products/fragola_h ... tings.aspx
i used a fitting with a tapered thread in the sump
Post by WideOpenThrottle » Mon May 17, 2010 7:24 pm
Yep just to make it awkward the engine is in the car :cry:
Thanks Keith i will wait to see what you have before i visit ENZED or say Waitemata Hydraulics so thanks to you as well sprsta :D
