Roof help
viscarious
Roof help
Post by viscarious » Sun Dec 06, 2009 11:18 pm
Hey there guys. So in real HEAVY rain my soft top is creating a mini lake on my passenger floor. in previous incidents I found that the first of the 3 weather strips contained alot of moisture inside. After doing a search I found out that the sides of these strips can become porous.
So my questions,
1)will putting silicone sealer on these strip ends fix my leak ( my roof is only 3 years old )
2) does a hardtop leak as much as a soft top?
Dave
Ben.Nakagawa
Post by Ben.Nakagawa » Mon Dec 07, 2009 7:46 am
Have you properly adjust your latch?
http://www.miata.net/garage/latch_adjust.html
Side rubber sealer fits well against window?
Those old rubber become hard and to conditioning this you can... believe or not ... use Vaseline gel. Spread it on the rubber in very thin coat.
I found this "Vaseline gel" trick on Miata.net. The guy suggested on multiple thread so I tried it and worked well.
Another thing is check the drain pile on front, if that is squashed.
Good luck.
Ben
Roof help
Post by poison » Mon Dec 07, 2009 9:21 am
There is also a thin cable that runs through all the way along the edge of
the soft top, if this cable is broken it loses it's tension along the edge
and the rubber does not push against the window as well. These cables often
break, in fact I'd say there are a lot of broken ones and most people don't
realise.
Word of caution on Vaseline, it used to be called petroleum jelly, which
will perish natural rubber. I'm not sure what the window rubbers are made
of, if synthetic they should be fine, if not.... uh ohhhh.... but you could
just play safe and use silicone grease, which feels the same as Vaseline but
won't damage rubber.
Petrolium Jelly
http://en.wikipedia.org/wiki/Petroleum_jelly
Ben.Nakagawa
Re: Roof help
Post by Ben.Nakagawa » Mon Dec 07, 2009 10:57 am
poison wrote:Word of caution on Vaseline, it used to be called petroleum jelly, which
Petrolium Jelly
Good advise! I'll stop using it (well, only done it once and holding quite bit.)
Either way, do not over done, just need very thin coat.
Ben
Re: Roof help
Post by Growler » Mon Dec 07, 2009 11:07 am
poison wrote:.... but you could just play safe and use silicone grease, which feels the same as Vaseline but won't damage rubber.
We are still talking MX5's here aren't we... :wink:
Re: Roof help
Post by Habanero666 » Mon Dec 07, 2009 11:20 am
Hahahaha :lol:
Roof help
Post by poison » Mon Dec 07, 2009 5:44 pm
Now who didn't see that coming..... LMAO
viscarious
Post by viscarious » Mon Dec 07, 2009 5:46 pm
Hmm well had a feel up of the rubber, heh, it feels kind of spongey?? looks it also?
Couldn't find that wire.
Might be stumbling upon some cash, do hardtops leak less/ at all?
Roof help
Post by jif » Mon Dec 07, 2009 9:33 pm
2009/12/7 viscarious <mx5talk@mx5forum.co.nz (mx5talk@mx5forum.co.nz)>
hardtops are leakfree, at least in my experience.  The better noise insulation and (perceived?) stiffiness was a another bonus :]
Ben.Nakagawa
Post by Ben.Nakagawa » Mon Dec 07, 2009 9:47 pm
Rubber is actually a tube. So, it feels spongy and it's normal.
Cable is on the side but not exactly at the edge as I remember, feel it inch or two inwards. While half close the top, you can slip your hand between fabric and frame/metal fitting.
...at least mine...
Ben
Users browsing this forum: Google [Bot] and 90 guests
