Trapped Water
Trapped Water
Have got the sound of water sloshing around on the left hand side. Sounded like in the door but thats dry. Can it get trapped in the sill? Any suggestions.
1989 NA Blue JRSC.
Yes it gets trapped in the rocker panels. Check your drainage points located in the front and rear jacking points on the sills underneath. I regularly clear them out with a twizzle stick (pipe cleaner). A good way to check this is to flow water over the top of the car and and check it is magicaly appearing underneath!
I will try to dig up some how to pic's
Please disregard the above posting, I will email you the scan John.
from wikianswers.com:
"Just below the passenger side door, along the outside edge of the bottom of your Miata, you'll find a seam where the sheet metal meets and has been welded together. Upon careful examination along the length of that seam, you'll find at least two small spots where the sheets of metal flair apart wide enough for coat hanger wire to slip inside. These holes are meant to drain the water that can collect in the body of your Miata after a hard rain. They can easily become clogged with dirt. To clear them, straighten out a coat hanger and gently slide one end into the hole about three inches to clear the obstruction. If water is currently sloshing around in the body, it should immediately begin to stream out. "
There was a service bulletin on this:
Clogged Side Sill drains (1994)
http://www.miata.net/garage/tsb/s034_94.html
The problem i have is that i have a body kit which seems to cover the area you are talking about. The first time it happened i took it to the local garage who claim to have drilled holes to let water out. The next time it hpappend on the other side of the car i looked to find the holes and duplicate them on the others side (since they charged me $60!!!) and lo and behold no holes. Not sure bout drilling thru the plastic/fibreglass bodykit which seems to be plastic welded ? onto the bottom of sill
