yee haa turbo has arrived!!!
something wierd with the ecu it keeps pulling spark just after 5000 its like knock controll is doing it but even with knock controll off the ceu still pulls back the numbers we put in bob reacons he could get more out of it with a newer model ecu
she was blowing copious amounts of black smoke on the first couple of runs no smoke at all now
it used to lean out when entering boost then get crazy rich, the afr is alot better now
Try a different spark plug? I understand turbos put different requirements on spark plugs and require different gaps, coldness etc?
If the ECU is pulling the spark, something is telling it to do it, and there arent many sensors that can do this other than knock or the rev limit are there? Makes me think its not the ECU stopping the spark but something in the ignition system itself.
Well it wouldn't be the knock sensor, as Cole has stated that timing is pulled with the knock correction function switched off.Could however be a wiring fault.
HAR HAR at a stab I would say the Soft rev limit!
Knock timing reduction will pull off degrees of timing, not reduce all timing to zero.
Also good point dynofiend, could be that timing at the CAS is incorrect or the cam driving it.
NEED MORE INFO COLE
NEED MORE INFO COLE
we checked base timing before setting it up on the dyno the cams were set at the factory position
limiter was set at 7200 so soft limit should come in about 7000 not 5200
we put numbers like 11 in and the knock controll should only pull 6 so i dont know where the other 5 went
i think i might start saving for a G4 miatalink slowly
is there anyone on here who has tried one yet?
possibly a cpu fault?
i might try changing to the chip i got from you andput my numbers into that
I'm using an older Link LEM V5 and have had no problems with it although I am not running a turbo. It came with default maps that got me going and then Gavin at High Velocity tuned it properly for me. I have had to call link a couple of times, mainly to do with the triggering from the CAS but it was nothing serious.
There are a couple of limitations with the LEM which I found after I had bought it but most of these would be addressed in the G3 or G4. These are mainly to do with the number of sensor inputs and drivers.
It all appears unusual, as I have the FM link version 1 (older than Coles) and it is a good piece of kit. Currently running 16psi manifold pressure @ 3000 rpm up to red line. Anything more and the power to chassis tuning balance is all out of kilter and the sports car becomes the skid pad mule.
I have achieved this with Link/ FM map, air temp sensors The rest are OEM or Bosch equivalent.
The knock sensor I use is from a series 5 RX7 running through a cocklink display only. It would require the version 2 map sensor to run knock function with this ecu.
I would have however, chosen to modify the ecu circuit board for both the air temp and WBO2 sensor. The air temp sensor has proven to be sufficient.
old thread i know but i think i have fixed the timing issue
i had abit of spare time this arvo for some poking around in the engine
there was a broken bolt in the starter motor bracket so have taken that out and replaced it
the bracket is right next to the sensor so may have been vibrating at certain loads/revs
ive put some numbers into the ign zones that were affected and they are still there
went for a hard boost and only recorded one knock in about half an hours hard driving
still not sure why it was taking timing out without knock controll on
would like to do a power run on a dyno to see how she goes now that i have some real power above 5500
HUGE difference
HUGE difference
SET KNK= 35 AND YOU SHOULD BE IN THE BALL PARK.
TO DISABLE KNOCK SENSOR SET THE VAUE TO 255.
Also what software version are you running as there has been some reported bugs with the earlier versions. To find this press both edit keys in the RPM screen.
I would say though you have fixed the problem with that rattle. If you used the value of 255 in the KNK screen it will be switched off and not making any adjustments to the ignition curve, simply leaving it on the default or setting it to ZERO is not switching it off.
You probably know this, but sometimes things get missed.
Hope it works out anyway
Jim
Jim
that dyno curve is a classic mx5 turbo line. There seems to be some sweet spots in the efficincy of the engine (or a couple of holes depending on how you look at it) that require a fair bit of fiddling to cure.
On my car it required a heap of fuel adjustments to flatten out the curves. the timing was fairly consistent as we just kept advancing the timing until we weren't seeing any real gains in HP from just timing changes.
