yee haa turbo has arrived!!!
got my T25 today seems to be all good i shouldnt even have to rebuild it.
thanks alot 2low2c for the manifold i have welded up anywhere i thought it may have a crack
i would rather have this manifold than any of those "high performance" ones from trade me
not long to go now
got an old evo 4 intercooler so will use that for now. but i would rather use something abit smaller like a vr4
so hopefully i should be boosted in acouple of weeks
cant wait
not long to go now
cant wait
Nice one!
Really looking forward to see the results of this set up! Good to see what kiwis are doing with their Roadsters!
What is the level of boost you will run with this turbo set up?
Do you know the A/R of this particular turbo? I am at the limits of efficiency at 16 psi with a TD04.
Anyways good luck with the set up and looking forward to reading some more.
yes:WideOpenThrottle wrote:Whats the prob' with high performance trademe manifolds,are they sus?
http://www.mx5forum.co.nz/viewtopic.php?t=8927
blew the seal on the top tank of the radiaror yesterday so got a new one with a bigger core.
we were abit quiet at work this arvo so i thought id start the turbo today.
oil feed is in and plumbing from throttle body to i/c is in guess ill start cutting and welding tomorrow for my new manifold im having abit of trouble finding an exhaust flange for the turbo guess ill have to get one cut.
other than that shes moving along nicely.
will get some pics up some time soon
boost breaks shit
im up for a clutch
i blame you 2low2c you said it would happen, so that speeded up the prosess
god HD clutches are expensive any ideas for a cost effective solution?
will give auto clutch a go tomorrow about an upgrade
it didnt even last 3 weeks under boost
brakes done today
cert should be done on monday
im up for a clutch
brakes done today
Have a talk to the guys at what used to be Trade Parts, 151 Wairau Road. They are now Exedy NZ and stock quite a good range. The Japanese Exedy stuff is good but avoid the Aussie HD stuff.
HD clutch
If you PM Habanero666 for a HD clutch he will supply and it won't kill the bank account! I use one in mine and it's handling 16psi.
