I am looking at installation of White dial faces on my 96 MX 5.
I have been quoted $250 inc GST from Parrats in town here for installation
only. As MXMart quote it only takes 2 hours and can be done for $60 does
anybody know any small size instrument firms that might be sensible about their
charges ?
Col
Col's law
* Thinly sliced cabbage *
Instrument Technician Christchurch
Col if you are even moderately handy with wielding a screwdriver there is a really good set of instructions I found on the MX website when I did this swap over four/five years ago. The whole exercise took me 3 hours start to finish (had no previous experience in it). It is not a difficult proposition by any means and does not require any specialist tools. Just a couple of screwdrivers and plenty of patience. Main problem I encountered was changing the colour of the needles - white on white isn't the best. I just scraped off the white and replaced on the underside with a vivid marker in red. One of the other tricks is to ensure you carefully record the dial settings for temperature, oil pressure etc. I managed to "lose" a couple of pounds oil pressure and "lower" the engine temps by a couple of degrees when refitting needles just ever so slightly off mark.
RobinT
RobinT
The problem I have seen with home made white face gauge replacements, is the
light dissipation at night. Most are shocking.
A friend of mine bought some EL Glow gauges for about $10. They were
American and in MPH. He simply ripped off the printing from the EL ( electro
luminescence ) sheet, printed a new one and stuck it back on. This is the
best installation I have ever seen. EL is a thin sheet of plastic that glows
when you apply a current. A pot will allow you to control the brightness.
Some even allow you to change colour.
Adrian
Adrian
Hi
Great info thanks, I had a look round the net and here's a link of an
interesting range of gauges... I'M ALREADY SOLD ...
http://motors.search.ebay.com/miata_Gau ... QQfromZR2Q
QgotopageZQQlopgZQQsacategoryZ33672QQsamotorscategorymapZ6028QQsapricehiZQQsa
priceloZQQsbrftogZ1QQsearchfiltersZQQsocolumnlayoutZ3QQsofocusZbsQQsosortorde
rZ2QQsosortpropertyZ2QQsotimeZ1QQsotrZ3
(good luck if you wanna type that in... or go to eBay and search on Miata
Gauges..
Gazza "PO1SON"
Gauges..
Gazza "PO1SON"
On Tue, 1 Jun 2004 12:10:58 +1200, you wrote:
Yankee ones are in MPH and not KPH.
Colin Francis
Krenford Holdings Ltd
P.O. Box 18547
Christchurch
New Zealand
www.westmorland.co.nz
The faces are obtainable here in NZ for 150 bucks + GST. Unfortunately theHi
Great info thanks, I had a look round the net and here's a link of an interesting range of gauges... I'M ALREADY SOLD ...
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
On Tue, 1 Jun 2004 9:12:45 +1200, you wrote:
take me I guess ) . I am looking for someone to do it for me at a reasonable
charge for cash.
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
Thanks for that Robin. i am too old and cranky to waste 5 hours (which it wouldCol if you are even moderately handy with wielding a screwdriver there is a really good set of instructions I found on the MX website when I did this swap over four/five years ago. The whole exercise took me 3 hours start to finish (had no previous experience in it). It is not a difficult proposition by any means and does not require any specialist tools. Just a couple of screwdrivers and plenty of patience. Main problem I encountered was changing the colour of the needles - white on white isn't the best. I just scraped off the white and replaced on the underside with a vivid marker in red. One of the other tricks is to ensure you carefully record the dial settings for temperature, oil pressure etc. I managed to "lose" a couple of pounds oil pressure and "lower" the engine temps by a couple of degrees when refitting needles just ever so slightly off mark.
RobinT
charge for cash.
Colin Francis
P.O. Box 18547
Christchurch
New Zealand
