Hand Brake on 94 1.8
I was refused a warrant on my 94 1.8 because the hand brake wasnt griping
equally on both sides.The left caliper is the one not gripping.
I had the pads changed and the whole system lubed
and adjusted without it making any difference.I was then told that when this
happens you have to change the caliper - they cant be fixed.To make matters
worse
I cant find a second hand caliper - there are plenty of 1.6's but no 1.8's.
My question is can they be fixed and can any one recommend someone in Auckland
who can do it.
Steve Easdon
Production Planning
Amcor Cartons Australasia
12-14 Lockhart Place
Mt Wellington
Auckland NZ
Ph: 64 09 9793833
worse
who can do it.
Steve Easdon
Production Planning
Mt Wellington
Auckland NZ
Ph: 64 09 9793833
try City Garage (central city), Rotary Power (N.Shore)
... or don't go to a testing station
--- Steve Easdon <Steve.Easdon@amcorcartons.co.nz>
I have heard that the left rear caliper is notorious for seizing or
otherwise failing in the MX5. Anyway, that's what happened to mine, so I
whipped the caliper out and had it reco'd at a place on Wairau Road for
under $150. Whacked it back in and away we go. Twelve months later and all
is still good.
North Harbour Brakes & Steering
126 Wairau Rd Glenfield Auckland
0-9-444 3573
Regards,
Phil H
is still good.
0-9-444 3573
Regards,
Phil H
Me too. My mechanic's concern was that you might then be back atI have heard that the left rear caliper is notorious for seizing or
I whipped the caliper out and had it reco'd at a place on Wairau Road
for under $150. Whacked it back in and away we go. Twelve months later
and all is still good.
square one and have to do the other one too to keep them
matched.
Try Sterling Brake and Clutch in Onehunga...
They re-built my 1.6 callipers...
Maybe you just need a seal kit? You can buy these from Mazda and rebuild it
yourself (or get a mechanic to rebuild it). If it is leaking slightly you
won't get pressure in the piston - so lubing won't make a difference.
I know of a 1.6 1990 with that exact prob.
H
H
Some one may have already answered this, but arent
the calipers on the 1.6 AND 1.8 the same?? I thought
that it was just the caliper mounting that was
different to accomadate the bigger caliper.
Glenn, the calipers on the front are the same (I've just put the 1.8
discs on the front with the 1.8 brackets and 1.6 calipers) but I believe
there is some difference in the handbrake system on the calipers between
the 1.6 and 1.8.
the 1.6 and 1.8.
The guys at Rotary Power who were trying to fix my hand brake found that
there is a difference between the 1.6 & 1.8 rear caliper.They had one to
compare.
But I have found out that they can be rebuilt ( thanks Fletch) so I'm
getting it done next week.
Thanks to everyone who replied.
Steve Easdon
Production Planning
Mt Wellington
Auckland NZ
Ph: 64 09 9793833
compare.
Steve Easdon
Production Planning
Mt Wellington
Auckland NZ
Ph: 64 09 9793833
The 1.8 callipers take a larger pad.The discs are bigger front and rear as well.Ross.
