Gritty gears
Mikkels
Gritty gears
Post by Mikkels » Sun Jun 22, 2003 7:03 pm
Hi
My 1990 has a slow syncro on second gear. Improves as the car warms but
is never really slick. Is this how they are or do I have a problem?
Can I improve things with synthetic oil or is that just a false hope?
Don
Fletch
Gritty gears
Post by Fletch » Mon Jun 23, 2003 5:53 am
Generally, they are all like that to some degree, especially the early ones
like yours and mine.
Type of oil can have some effect at changing the feel, and also there is a
"shift turret" that needs oil too... basically to lubricate the lever pivot
mechanism... but don't expect miracles...
lou Girardin
Gritty gears
Post by lou Girardin » Mon Jun 23, 2003 8:11 am
Using synthetic improved mine. Try Amsoil or Redline.
jeff
Gritty gears
Post by jeff » Mon Jun 23, 2003 8:57 am
Lou, where can you get Amsoil from locally?
I picked up some Redline MTL from Kendall Racing
supplies but it's made the shifting more "visceral"
... I'll try something else if I can.
Funnily enough, my sister's newly acquired '90 shifts
like a dream!
Jeff
'96 mod-mobile
--- lou Girardin <lou@mongoose.co.nz> wrote:
lou Girardin
Gritty gears
Post by lou Girardin » Mon Jun 23, 2003 9:20 am
They're based in New Lynn, 827 8442. I don't know if they sell direct to the
public, try calling for a local dealer.
Interesting comment on Redline, the Yanks rave about it.
I found Amsoil much better than Castrol synthetic.
xtr515758
Gritty gears
Post by xtr515758 » Mon Jun 23, 2003 1:06 pm
MInes not a grinder, but I definately have to be a little slower and more deliberate with shifting 1st to 2nd, esp when cold (93, 97,000km). A friends 92 is identical. Looking on Miata.net, there's plenty to read on this subject. Most people advocate synthetic oil in the 'box, and changing the turret oil, but reading the responses of people who have tried this, the outcome seems about as variable as the severity of the problem in the first place. I don't worry about it, and find it minimally irritating.
Muscles
Gritty gears
Post by Muscles » Mon Jun 23, 2003 5:44 pm
Can Anyone shed some light on the changing of turret oil saga...as im due an
oil change in my '89 and i have the same second gear trouble maybe ill change
the turret oil as well...
can anyone also tell me if when it gets close to oil change time if there car
has the old noisy tappets at idle occasionaly?
cheers,
Gareth.
rotarypower
Gritty gears
Post by rotarypower » Mon Jun 23, 2003 5:50 pm
put valvoline syntrans gear oil in the trans 75w/85w mazda boxs dont
like thick oil in them,it will feel much better,changing the oil in the
gear shift housing wont fix it ,as the shaft only goes backwards and
forwards ,its the syncro and hubs in the trans that do the work,if that
doesnt work fix the problem in the trans>glenn munro
Muscles wrote:
Chic & Morven
Gritty gears
Post by Chic & Morven » Tue Jun 24, 2003 6:53 pm
The club web site has a page on changing the rubber shift boot, which is
more or less what you need to do to change the turret oil.
http://www.mx5club. org.nz/maintenance/shift_boots/ As for the tappet
noise... when I hear that I know it's time to change my oil. It's quite
a handy reminder. On Mon, 23 Jun 2003 17:44:46 +1200, Muscles wrote: >Can
Anyone shed some light on the changing of turret oil saga...as >im due
an oil change in my '89 and i have the same second gear >trouble maybe
ill change the turret oil as well... > >can anyone also tell me if when
it gets close to oil change time if >there car has the old noisy tappets
nmr
Gritty gears
Post by nmr » Tue Jun 24, 2003 10:08 pm
As for the tappet noise... when I hear that I know it's time to
change my oil. It's quite a handy reminder.
I hate "me too" contributions to egroups but this needs reinforcing:
"yes, that's right!"
Return to “2003”
