cheap ECU
jeff
cheap ECU
Post by jeff » Wed May 21, 2003 1:20 pm
wow, someone's actually using a Greddy e-manage on a MX5 now...
http://www.miataforum.com/ubb/ultimateb ... p=1#000009
at ~US$300, it's worth looking into for all you other power freaks. Both of you ! ;-)
Jeff
The New Yahoo! Search - Faster. Easier. Bingo.
Mathew
cheap ECU
Post by Mathew » Wed May 21, 2003 2:06 pm
it doesn't look too great if the biggest injectors It'll handle are only 50% bigger than stock.
M@
jeff
cheap ECU
Post by jeff » Thu May 22, 2003 1:00 am
maybe you could work around it with a rising rate fuel
pressure regulator. You'd need to do that with a Bipes
ACU anyway.
BTW - those Mintex brake pads seem pretty good,
noticeably more dusty tho'. Have to admit I don't use
the brakes much ;) :D
--- Mathew <mathew.avery@deepvideo.com> wrote:
Cory
cheap ECU
Post by Cory » Thu May 22, 2003 8:15 am
If anyone is interested I have a Link LEM which has latest program and has
been setup for piggyback on MX5 ECU. can be used to control timing and fuel
only.
David & Judy Kerr
cheap ECU
Post by David & Judy Kerr » Thu May 22, 2003 7:42 pm
How much Cory?
Dave
Cory
cheap ECU
Post by Cory » Fri May 23, 2003 7:48 am
$650 has latest software and new com link and cables to connect to pc
Return to “2003”
