attn ray
Glen McLean
attn ray
Post by Glen McLean » Mon May 14, 2001 6:14 pm
Ray, I have the use of a hoist at work, and therefore have found that by
hitting the sill i can hear the offending object bouncing around in there. I
think it's a stone, and therefore non metalic (laughs) stone=metel, get it?
Today I repaired the problem with the slow electric windows, by fitting
factory relays out of a late model mazda 626. Now the windows work like new
(in fact better than). I had to dismantel the switch, and clean up the
carbon build up. They now work like they should!!!
thanks, glen
Glen McLean
attn ray
Post by Glen McLean » Mon May 14, 2001 7:11 pm
1997 626.
Yes I may have to resort to cutting the beast up!!
I have a rather good (tuned) ear for these things. and it may well be a hunk
of bog. i think the car is pretty straight though, (laughs).
The relay thing is simple, the plugs for the relay ('97 626) fit the mx5
plugs, (the ones under the gear-lever) and all you do is re-arrange the
wires a wee bit, and source power from the fuse panel, and earth from
somewhere.
has anyone ever cut into the panel behind the seats to install speakers,
(6x9) ???
Return to “2001”
